HPE HP ProLiant DL80 Gen9 Intel Xeon E5-2603V3 4GB
Quicklinx: BMNJWS00 Mfr#: M1G10A
  • Xeon
  • Red Hat Enterprise Linux
Do you need an affordable storage server for capacity intensive applications? The HP ProLiant DL80 Gen9 Server is designed with affordable storage, networking, processor scalability, and manageability in a 2U server for cost conscious service provider and SMBs. Apart from basic IT infrastructure workloads this server is ideal for running storage capacity intensive applications like cold storage and back-up due to the compelling cost/GB that it offers.
  • Affordable Storage and IO Expandability for Service Providers and SMBs
    The HPE ProLiant DL80 Gen9 Server provides ample storage capacity with up to (12) Large Form Factor (LFF) HPE SmartDrives, delivering optimal performance, capacity, and reliability to meet various customer segments and workload requirements at the right economics.Up to (6) PCIe 3.0 riser slots to support one single-wide GPU or networking cards offering increased IO bandwidth and seamless expandability.Comes standard with 2x1GbE and choice of HPE FlexibleLOM to provide you flexibility of networking bandwidth and fabric so you can adapt to changing business needs.With support for Large Form Factor (LFF) hard disk drives (HDDs) with up to 10 TB capacity DL80 Gen9 offers maximum storage of up to 120 TB SAS/SATA.
  • Just Enough Performance for Basic IT Infrastructure Workloads
    The HPE ProLiant DL80 Gen9 Server supports up to two (2) Intel Xeon processor E5-2600 v4 processors offering improved performance and efficiency.HPE SmartMemory has the built-in intelligence to improve performance, reduce downtime and energy costs resulting in up to 14% better throughput performance and up to 37% lower power consumption with DDR4 memory.Embedded SATA HPE Dynamic Smart Array B140i Controller for boot and data. Choice of HPE Smart Array Controllers with increased performance, data availability with 12 Gb/s SAS technology or HPE Smart HBAs with reliable high performance SAS connectivity capable of running HBA mode or simple RAID mode.
  • Agile Infrastructure Management for Accelerating IT Service Delivery
    Included with the HPE ProLiant DL80 Gen9 Server is HPE OneView providing infrastructure management for automation simplicity across servers, storage and networking.Online personalized dashboard for Converged Infrastructure (CI) health monitoring and support management with HPE Insight Online.Configure in Unified Extensible Firmware Interface (UEFI) boot mode, provision local and remote with Intelligent Provisioning and Scripting Toolkits or HPE RESTful Interface Tool for increased flexibility.Embedded management to deploy, monitor and support your server remotely, out of band with HPE Integrated Lights-Out (iLO).Optimize firmware and driver updates and reduce downtime with Smart Update, consisting of SUM (Smart Update Manager) and SPP (Service Pack for ProLiant).
  • Energy Efficiency by Design
    HPE ProLiant DL80 Gen9 Server with 80 PLUS gold certified entry-level redundant HPE Power Supplies provide up to 92% efficiency which combined with HPE power management features leads to reduction of power consumption and expense.Improved ambient temperature standard with ASHRAE A3 helps customers reduce cooling expense.
HPE ProLiant DL80 Gen9 - rack-mountable - Xeon E5-2603V3 1.6 GHz - 4 GB - no HDD
Server - rack-mountable - administrator password, power-on password, UEFI BIOS
Height (Rack Units)
2U
Server Scalability
2-way
1 x Intel Xeon E5-2603V3 / 1.6 GHz (6-core)
Cache Memory
15 MB L3 Cache
Cache Per Processor
15 MB
RAM
4 GB (installed) / 128 GB (max) - DDR4 SDRAM - Advanced ECC - PC4-17000
Storage Controller
RAID (SATA 6Gb/s) (HP Dynamic Smart Array B140i)
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Matrox G200eH2
GigE
44.55 cm x 60.7 cm x 8.75 cm
16.59 kg
Manufacturer Selling Program
HP Top Value
Limited warranty - parts and labour - 1 year - on-site
Server
Product Form Factor
Rack-mountable - 2U
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Server Scalability
2-way
Processor / Chipset
CPU
Clock Speed
1.6 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Cache Memory
Installed Size
L3 Cache - 15 MB
Cache Per Processor
15 MB
RAM
Installed Size
4 GB / 128 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
8 (Total)
Registered, Online Spare Memory, quad channel memory architecture, HP SmartMemory
RAM Supported
128 GB registered , 256 GB Load-Reduced
Hard Drive
No HDD
Storage Controller
1 x RAID - integrated
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
Channel Qty
10
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200eH2
Video Interfaces
VGA
Integrated
Interface (Bus) Type
PCI Express 2.0 x2
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
HP NC361i
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1as, IEEE 802.3az
Bays
8 (total) / 8 (free) x 3.5" LFF
Slots
2 (total) / 1 (free) x CPU , 8 DIMM 288-pin , 3 (total) / 3 (free) x PCIe 3.0 x16 - low-profile , 2 (total) / 2 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x microSD Card (internal)
2 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x USB 2.0 (1 in front) , 3 x USB 3.0 (2 rear, 1 internal)
HPE Easy Install Rails
Administrator password, power-on password, UEFI BIOS
ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 4943, GB 9254, ASHRAE, CNS 13438, BSMI CNS 14336-1
HP Top Value
Power supply
Power Provided
550 Watt
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris
44.55 cm
60.7 cm
8.75 cm
16.59 kg
10 °C
35 °C
8 - 90% (non-condensing)
