Are you looking for affordable compute but in a dense design? The HPE ProLiant DL60 Gen9 Server provides the right density, performance and manageability for file and print, messaging, collaboration workloads and cloud environments. All in a compact 1U chassis at an affordable price to meet the needs of cost conscious service providers and SMBs.
Price Performance for Budget Constrained Environments
The HPE ProLiant DL60 Gen9 Server supports up to (2) Intel Xeon E5-2600 v3/v4 processors and eight (8) DIMM slots of HPE DDR4 SmartMemory offering improved efficiency and up to 14% performance increase.Standard with 2x1GbE, up to (3) PCIe slots and choice of HPE FlexibleLOM provide you flexibility of networking bandwidth and fabric so you can adapt and grow to changing business needs.Choice of HPE Smart Array Controllers with increased performance, data availability with the 12 Gb/s SAS technology or HPE Smart HBAs with reliable high performance SAS connectivity capable of running HBA mode or simple RAID mode.HPE SmartDrives continue to deliver optimal performance, capacity, and reliability to meet various customer segments and workload requirements at the right economics. Supports up to (4) LFF HDD/SSD options. -
Density and Efficiency packaged in a Cost Optimized Design
The HPE ProLiant DL60 Gen9 Server offers efficiency in a 1U cost optimized design at an affordable price point for SMBs with basic file and print or messaging needs to Service providers with cloud environments.80 PLUS gold certified entry-level HPE Power Supplies provide up to 92% efficiency which combined with HPE power management features leads to reduction of power consumption and expense.Improved ambient temperature standard with ASHRAE A3 helps customers reduce cooling expense. -
Agile Infrastructure Management for Accelerating IT Service Delivery
With HPE ProLiant DL60 Gen9 Server, HPE OneView provides infrastructure management for automation simplicity across servers, storage and networking.Online personalized dashboard for converged infrastructure health monitoring and support management with HPE Insight Online.Configure in Unified Extensible Firmware Interface (UEFI) boot mode, provision local and remote with Intelligent Provisioning and Scripting Toolkits or HPE RESTful Interface Tool.Embedded management to deploy, monitor and support your server remotely, out of band with HPE iLO.Optimize firmware and driver updates and reduce downtime with Smart Update, consisting of SUM (Smart Update Manager) and SPP (Service Pack for ProLiant).
- HPE ProLiant DL60 Gen9 - rack-mountable - Xeon E5-2603V3 1.6 GHz - 8 GB
- Server - rack-mountable
- Height (Rack Units)
- 1U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2603V3 / 1.6 GHz (6-core)
- Processor Socket
- FCLGA2011-v3 Socket
- Processor Main Features
- Intel Smart Cache
- Cache Memory
- 15 MB
- Cache Per Processor
- 15 MB
- RAM
- 8 GB (installed) / 256 GB (max) DDR4 SDRAM - Advanced ECC - PC4-17000
- Storage Controller
- RAID (SATA 6Gb/s) (HP Dynamic Smart Array B140i)
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200eH2
- Networking
- GigE
- 43.46 cm x 60.7 cm x 4.29 cm
- 9 kg
- Manufacturer Selling Program
- HP Top Value
- Limited warranty - parts and labour - 1 year - on-site
- Server
- Product Form Factor
- Rack-mountable - 1U
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 2-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 4
Processor / Chipset
- CPU
- Intel Xeon E5-2603V3 / 1.6 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- Intel Smart Cache
- CPU Socket
Cache Memory
- Installed Size
- 15 MB
- 15 MB
RAM
- Installed Size
- 8 GB / 256 GB (max)
- Technology
- DDR4 SDRAM - Advanced ECC
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 8 (Total)
- Registered, Online Spare Memory, quad channel memory architecture, HP SmartMemory
- RAM Supported
- 256 GB registered - Advanced ECC , 256 GB Load-Reduced - Advanced ECC
Hard Drive
- No HDD
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- HP Dynamic Smart Array B140i
- Channel Qty
- 10
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Matrox G200eH2
- Video Interfaces
- VGA
- Interface (Bus) Type
- PCI Express 2.0 x2
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- HP NC361i
- Data Link Protocol
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1as, IEEE 802.3az
- Bays
- 4 (total) / 4 (free) x hot-swap 3.5" LFF , 1 (total) / 1 (free) x external 5.25"
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x microSD Card (internal)
- 2 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x USB 2.0 (1 in front) , 3 x USB 3.0 (2 rear, 1 internal)
- Included Accessories
- HP Easy Install Rails
- ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 9254, ASHRAE, CNS 13438
- HP Top Value
- Power supply
- Power Provided
- 900 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Efficiency
- 92%
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
- 43.46 cm
- 60.7 cm
- 4.29 cm
- 9 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
