HPE HP ProLiant DL60 Gen9 Intel Xeon E5-2603v3 4GB
Quicklinx: BGLFWS00 Mfr#: 788078-425
  • Xeon
  • Red Hat Enterprise Linux
  • DVD-RW
Are you looking for affordable compute but in a dense design? The HPE ProLiant DL60 Gen9 Server provides the right density, performance and manageability for file and print, messaging, collaboration workloads and cloud environments. All in a compact 1U chassis at an affordable price to meet the needs of cost conscious service providers and SMBs.
  • Price Performance for Budget Constrained Environments
    The HPE ProLiant DL60 Gen9 Server supports up to (2) Intel Xeon E5-2600 v3/v4 processors and eight (8) DIMM slots of HPE DDR4 SmartMemory offering improved efficiency and up to 14% performance increase.Standard with 2x1GbE, up to (3) PCIe slots and choice of HPE FlexibleLOM provide you flexibility of networking bandwidth and fabric so you can adapt and grow to changing business needs.Choice of HPE Smart Array Controllers with increased performance, data availability with the 12 Gb/s SAS technology or HPE Smart HBAs with reliable high performance SAS connectivity capable of running HBA mode or simple RAID mode.HPE SmartDrives continue to deliver optimal performance, capacity, and reliability to meet various customer segments and workload requirements at the right economics. Supports up to (4) LFF HDD/SSD options.
  • Density and Efficiency packaged in a Cost Optimized Design
    The HPE ProLiant DL60 Gen9 Server offers efficiency in a 1U cost optimized design at an affordable price point for SMBs with basic file and print or messaging needs to Service providers with cloud environments.80 PLUS gold certified entry-level HPE Power Supplies provide up to 92% efficiency which combined with HPE power management features leads to reduction of power consumption and expense.Improved ambient temperature standard with ASHRAE A3 helps customers reduce cooling expense.
  • Agile Infrastructure Management for Accelerating IT Service Delivery
    With HPE ProLiant DL60 Gen9 Server, HPE OneView provides infrastructure management for automation simplicity across servers, storage and networking.Online personalized dashboard for converged infrastructure health monitoring and support management with HPE Insight Online.Configure in Unified Extensible Firmware Interface (UEFI) boot mode, provision local and remote with Intelligent Provisioning and Scripting Toolkits or HPE RESTful Interface Tool.Embedded management to deploy, monitor and support your server remotely, out of band with HPE iLO.Optimize firmware and driver updates and reduce downtime with Smart Update, consisting of SUM (Smart Update Manager) and SPP (Service Pack for ProLiant).
HPE ProLiant DL60 Gen9 - rack-mountable - Xeon E5-2603V3 1.6 GHz - 4 GB
Server - rack-mountable
Height (Rack Units)
1U
Server Scalability
2-way
1 x Intel Xeon E5-2603V3 / 1.6 GHz (6-core)
Processor Socket
FCLGA2011-v3 Socket
Processor Main Features
Intel Smart Cache
Cache Memory
15 MB
Cache Per Processor
15 MB
RAM
4 GB (installed) / 256 GB (max) DDR4 SDRAM - Advanced ECC - PC4-17000
Storage Controller
RAID (SATA 6Gb/s) (HP Dynamic Smart Array B140i)
Hard Drive
No HDD
Optical Storage
DVD-Writer
Graphics Controller
Matrox G200eH2
GigE
43.46 cm x 60.7 cm x 4.29 cm
9 kg
Limited warranty - parts and labour - 1 year - on-site
Server
Product Form Factor
Rack-mountable - 1U
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Server Scalability
2-way
Internal Bays Qty
4
Processor / Chipset
CPU
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Intel Smart Cache
CPU Socket
FCLGA2011-v3 Socket
Cache Memory
Installed Size
15 MB
Cache Per Processor
15 MB
RAM
Installed Size
4 GB / 256 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
8 (Total)
Registered, Online Spare Memory, quad channel memory architecture, HP SmartMemory
RAM Supported
256 GB registered - Advanced ECC , 256 GB Load-Reduced - Advanced ECC
Hard Drive
No HDD
Storage Controller
1 x RAID - integrated
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
Channel Qty
10
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200eH2
Video Interfaces
VGA
Integrated
Interface (Bus) Type
PCI Express 2.0 x2
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
HP NC361i
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1as, IEEE 802.3az
Bays
4 (total) / 4 (free) x internal 3.5" LFF , 1 (total) / 0 (free) x external 5.25"
Slots
1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x microSD Card (internal)
2 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x USB 2.0 (1 in front) , 3 x USB 3.0 (2 rear, 1 internal)
Administrator password, power-on password, UEFI BIOS
ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 9254, ASHRAE, CNS 13438
Power supply
Nominal Voltage
Power Provided
550 Watt
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
43.46 cm
60.7 cm
4.29 cm
9 kg
10 °C
35 °C
8 - 90% (non-condensing)
BGLF C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
