HP ProLiant DL585 G7, the versatile workhorse for the evolving datacenter, is a flexible 4-socket multi-core rack mount server with the expansion capabilities ideal for server virtualization, server consolidation, multi-tiered enterprise applications, and corporate infrastructure applications.
Outstanding Performance/Price and Scalability
The HP ProLiant DL585 G7 Server offers greater I/O expansion, the latest 16 core AMD Opteron processors, and DDR3 memory expandable to 1.5 TB to allow you to scale up as the business grows.The HP 4S architecture, a 10 Gb NIC upgrade option, up to eleven I/O slots, and industry leading management solutions make the HP ProLiant DL585 ideal for virtualization.AMD Opteron 6300 Series Processors provide new levels of performance and efficiency over the previous generation, with a high core density and scalability to handle demanding multi-threaded workloads in cloud computing, virtualization, HPC, and database applications. -
Industry Leading Management Solutions
HP Insight Control measures, meters and caps power usage on individual and groups of servers to optimize power usage, driving significant gains to data center capacity.HP Insight Control provides the ability to watch recorded boot and failure sequences, remote power on and power off, thereby enabling customers to dramatically reduce troubleshooting time, cost, and travel expenses. Functionality is provided by HP iLO Advanced.Reduce unplanned downtime by up to 83% - IDC: "Gaining Business Value and ROI with HP Insight Control Management Software," March 2012. -
High Efficiency and Enhanced Flexibility for a Variety of Enterprise Deployments
Efficient power supply options, HP power adviser, HP Insight Control, and latest AMD Opteron 16 core processors enhance performance while keeping power consumption at the same level.Support for the industry's most popular operating systems, including Microsoft Windows Server, Red Hat Enterprise Linux, SUSE Linux Enterprise Server, and VMware.Designed to fit into existing enterprise data centers, with support for full line of HP Smart Array controllers, NICs, storage options, and HP Common Slot Power Supplies. -
HP Converged Infrastructure Based Solution
HP offers a full portfolio of standards-based, integrated solutions and services developed specifically to solve the complexities of the data center.By simplifying, integrating and automating technology, Converged Infrastructure accelerates outcomes that matter: faster time to revenue; lower acquisition and implementation costs; flexible response to business changes; lower risks.
- HPE ProLiant DL585 G7 Performance - rack-mountable - Opteron 6376 2.3 GHz - 64 GB - no HDD
- Server - rack-mountable - administrator password, power-on password, keyboard password, diskette I/O control, serial port I/O control, USB port control, 80 PLUS Platinum Plus
- Height (Rack Units)
- 4U
- Localisation
- Region: Europe
- Server Scalability
- 4-way
- Processor
- 4 x AMD Opteron 6376 / 2.3 GHz (3.2 GHz) (16-core)
- Cache Memory
- 64 MB L3 Cache
- Cache Per Processor
- 16 MB
- RAM
- 64 GB (installed) / 1.5 TB (max) - DDR3 SDRAM - PC3-10600
- Storage Controller
- RAID (SATA 3Gb/s / SAS 6Gb/s) - PCIe 2.0 x4 (Smart Array P410i with 1GB FBWC)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- ATI ES1000
- Video Memory
- 32 MB DDR SDRAM
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Software Included
- HP Insight Control
- 48.3 cm x 70 cm x 17.6 cm
- 30 kg
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Rack-mountable - 4U
- 4-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 8
- Localisation
- Region: Europe
Processor / Chipset
- CPU
- AMD Opteron 6376
- Clock Speed
- 2.3 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- 16-core
- CPU Qty
- 4
- Max CPU Qty
- 4
- CPU Upgradability
- Upgradable
- Chipset Type
- AMD SR5690/SP5100
Cache Memory
- Installed Size
- L3 Cache - 64 MB
- 16 MB
RAM
- Installed Size
- 64 GB / 1.5 TB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1333 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3-10600
- Form Factor
- DIMM 240-pin
- Slots
- 48 (Total) / 40 (empty)
- Registered
- Configuration Features
- 8 x 8 GB
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - integrated - PCIe 2.0 x4
- Controller Interface Type
- SATA 3Gb/s / SAS 6Gb/s
- Storage Controller Name
- Smart Array P410i with 1GB FBWC
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
- Buffer Size
- 1 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- ATI ES1000
- Video Memory
- 32 MB DDR SDRAM
- Video Interfaces
- VGA
- Integrated
- Interface (Bus) Type
- PCI Express 2.0 x4
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- HP 331i
- Data Link Protocol
- Remote Management Controller
- Integrated Lights-Out 3
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3az
- Bays
- 1 (total) / 1 (free) x external 5.25" Slim Line , 8 (total) / 8 (free) x hot-swap 2.5" SFF
- Slots
- 48 (total) / 40 (free) x DIMM 240-pin , 4 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 2.0 x16 , 3 (total) / 3 (free) x PCIe 2.0 x16 (x8 mode) , 1 (total) / 1 (free) x SD card
- 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 6 x USB 2.0 (2 front, 2 rear, 2 internal) , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 2 x VGA (1 front, 1 rear)
- Administrator password, power-on password, keyboard password, diskette I/O control, serial port I/O control, USB port control, 80 PLUS Platinum Plus
- ACPI 2.0, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, BSMI CNS 13438
- Power supply - hot-plug
- Power Redundancy
- Power Redundancy Scheme
- N+N
- Installed Qty
- 4
- Max Supported Qty
- 4
- Voltage Required
- Power Provided
- 1200 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Efficiency
- 94%
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris, Citrix XenServer
- Software
- 48.3 cm
- 70 cm
- 17.6 cm
- 30 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
