Does your enterprise data center demand uncompromised performance and cutting-edge resiliency at a lower total cost of ownership? The HP ProLiant DL580 Gen8 Server is an enterprise-grade four socket (4S) x86 server offering breakthrough performance, rock-solid reliability, and compelling consolidation and manageability efficiencies. It is ideal for mission-critical enterprise, business intelligence, and database applications. Featuring Intel Xeon E7-4800 v2 processors, the HP DL580 Gen8 offers blazing fast results with enhanced processor performance, more memory slots (96 DIMMs), greater IO bandwidth (9 PCIe Gen3.0 slots), and increased storage performance (12 Gbps SAS) over the HP DL580 G7 systems. HP ProLiant DL580 Gen8 has security and data protection features for system resiliency that your business can depend on. With intelligent manageability through HP OneView, iLO 4, and user-inspired features, you get faster, lower cost infrastructure management.
Breakthrough Performance and Scalability
The HPE ProLiant DL580 Gen8 Server provides up to 2x processor performance and 50% more cores with Intel Xeon E7-4800 v2 processors than the previous generation.Allows you to implement large-scale in-memory computing and virtualization with more memory slots (96 DIMMs).Supports more PCIe flash storage or co-processor cores to boost performance with greater I/O bandwidth: 9 PCIe Gen3 slots including 5 x16 FL/FH slots.Increases SSD performance with 12 Gbps HPE Smart Array SAS Controllers and greater internal storage capacity for faster access to more data. -
Leading Availability and Reliability
The HPE ProLiant DL580 Gen8 Server provides increased system availability and less need for service with enhanced error recovery, improved error diagnosis, and built-in redundancy.Improves reliability and data protection with HPE Smart Array Controllers featuring 4 G cache, Advanced Data Mirroring, and HPE SmartDrive technology.Increases security with support for Unified Extensible Firmware Interface (UEFI) mode, Secure Boot, HPE Secure Encryption, and Intel Secure Key.HPE Proactive Care Services integrates uptime and productivity into a personalized, simplified support experience. -
Compelling Efficiencies with Intelligent Manageability and Scale-up Consolidation
The HPE ProLiant DL580 Gen8 Server provides total cost of ownership savings with scale-up consolidation efficiencies and software licensing cost savings.Faster, lower-cost infrastructure management and a single integrated view of your IT infrastructure with HPE OneView.Provides up to 3x faster administrative updates with 93% less downtime and 69% less operator time through industry-leading maintenance tools with HPE Smart Update Manager (SUM).Comprehensive embedded manageability with HPE iLO 4, HPE Agentless Management, HPE Active Health System, HPE Intelligent Provisioning, and HPE Embedded Remote Support.User-inspired features such as FlexibleLOM for a choice in networking, front access processor/memory drawer for ease of serviceability, and QR code for quick access to product information.
- HPE ProLiant DL580 Gen8 High Performance - rack-mountable - Xeon E7-4890v2 2.8 GHz - 128 GB - no HDD
- Server - rack-mountable - administrator password, power-on password, keyboard password, serial port I/O control, USB port control, 80 PLUS Platinum Plus
- Height (Rack Units)
- 4U
- Localisation
- Region: Europe
- Server Scalability
- 4-way
- Processor
- 4 x Intel Xeon E7-4890v2 / 2.8 GHz (, up to 3.4 GHz, (15-core)
- Cache Memory
- 150 MB L3 Cache
- Cache Per Processor
- 37.5 MB
- RAM
- 128 GB (installed) / 3 TB (max) - DDR3 SDRAM - PC3-14900
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 2.0 x4 (Smart Array P830i with 2GB FBWC)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200
- Networking
- 10 GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Software Included
- HP Insight Control
- 48.3 cm x 70 cm x 17.6 cm
- 30 kg
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Rack-mountable - 4U
- Embedded Security
- Trusted Platform Module (TPM) Security Chip
- 4-way
- Hot-Swap Bays Qty
- 10
- Localisation
- Region: Europe
Processor / Chipset
- CPU
- Intel Xeon E7-4890v2
- Clock Speed
- 2.8 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- 15-core
- CPU Qty
- 4
- Max CPU Qty
- 4
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C602J
Cache Memory
- Installed Size
- L3 Cache - 150 MB
- 37.5 MB
RAM
- Installed Size
- 128 GB / 3 TB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1866 MHz
- Memory Specification Compliance
- PC3-14900
- Form Factor
- DIMM 240-pin
- Slots
- 96 (Total) / 80 (empty)
- Registered, Online Spare Memory, quad channel memory architecture, HP SmartMemory
- Configuration Features
- 16 x 8 GB
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - integrated - PCIe 2.0 x4
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- Smart Array P830i with 2GB FBWC
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
- Buffer Size
- 2 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox G200
- Video Interfaces
- VGA
- Plug-in card
- Interface (Bus) Type
- FlexibleLOM
- Ethernet Ports
- 2 x 10 Gigabit Ethernet
- Ethernet Controller
- HP FlexFabric 534FLR-SFP+
- Data Link Protocol
- 10 Gigabit Ethernet
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), ACPI support, PXE support
- IEEE 802.3, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.1AX, IEEE 802.1Qbb, IEEE 802.1Qaz, IEEE 802.1Qau, IEEE 802.1Qbg, IEEE 802.2x
- Bays
- 10 (total) / 10 (free) x hot-swap 2.5" SFF
- Slots
- 96 (total) / 80 (free) x DIMM 240-pin , 4 (total) / 0 (free) x CPU , 5 (total) / 5 (free) x PCIe 3.0 x16 - full-length, full-height , 4 (total) / 4 (free) x PCIe 3.0 x16 - half-length, full-height (x8 mode) , 1 (total) / 0 (free) x FlexibleLOM , 1 (total) / 1 (free) x microSD Card
- 1 x serial , 2 x VGA (1 front, 1 rear) , 1 x HPE iLO , 8 x USB 2.0 (2 front, 4 rear, 2 internal) , 2 x LAN (10Gigabit Ethernet) (SFP+)
- Included Accessories
- Rack rail kit
- Administrator password, power-on password, keyboard password, serial port I/O control, USB port control, 80 PLUS Platinum Plus
- ACPI 2.0, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 9254, CNS 13438
- Power supply - hot-plug
- Power Redundancy
- Power Redundancy Scheme
- 2+2
- Installed Qty
- 4
- Max Supported Qty
- 4
- Voltage Required
- Power Provided
- 1500 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
- Software
- 48.3 cm
- 70 cm
- 17.6 cm
- 30 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.89 |
