HPE HP ProLiant DL560 Gen8 Intel Xeon E5-4603 16GB (2x8GB) NO HDD
Quicklinx: 9NRPWS00 Mfr#: 686786-421
  • Xeon
  • Red Hat Enterprise Linux
The HP ProLiant DL560 Gen8 server, latest server in the ProLiant Scale-up x86 portfolio, that redefines density-optimized 4-socket rack server technology without compromising on performance, scalability, and expandability. Built on the latest Gen8 innovative and intuitive hardware and software features and supporting the new high-density and cost effective Intel Xeon E5-4600v2 processors, the DL560 Gen8 is ideal for virtualization, server consolidation, database, business processing, and general 4P data-intensive applications where optimization of data center space and price/performance is paramount.
  • Ideal 4S/2U Dense Form Factor without Compromising on Performance, Scalability, and Expandability
    Providing 4S computing in a dense 2U form factor, the ProLiant DL560 supports up to four cost-effective Intel Xeon E5-4600v2 processors each up to 12 cores and 130 watts without system configuration restrictions.HPE Smart Storage technology is designed to remove storage bottlenecks and turbo-charge data-intensive application performance to accelerate workloads. Support for the HPE Smart Array P420i RAID controller with optional 1GB or 2GB Flash Backed Write Cache.Up to six PCIe 3.0 expansion slots (up to 3 x16), this technology supports the highest performing option cards now and into the future and provides improved latency of up to 400% the bandwidth per I/O expansion slot compared to Gen7 servers.HPE FlexibleLOM provides you a choice of networking bandwidth and fabric so you can adapt to changing business needs.HPE SmartMemory prevents data loss and downtime with enhanced error handling while improving workload performance and power efficiency. Support for 48 DDR3-DIMM sockets for up to 1.5TB max capacity.
  • Redefining the Customer Experience with HPE ProActive Insight architecture
    Redefining the Customer Experience with HPE ProActive Insight architecture User-inspired design features that prevent data loss, reduce downtime, and improve serviceability include HPE SmartDrives, "Snap and Go" rail kit options, and tool-less access to components.Integrated Lifecycle Automation provides intuitive system management with simplified provisioning, proactive health monitoring and alerting, and automated firmware and system software maintenance.Dynamic Workload Acceleration converges storage, compute, and I/O to turbo-charge performance and resiliency while eliminating bottlenecks.Automated Energy Optimization reclaims space, power, and cooling resources needed for workloads and extends your data center capacity.HPE proactive support services enable industry leading performance, uptime and productivity integrated into a personalized, simplified support experience.
  • Unlock your Infrastructure's Potential with HP's Easy-to-Use Integrated Management and Support
    HPE iLO Management Engine is a complete set of embedded features, standard on all ProLiant Gen8 servers. Includes HPE iLO, HPE Agentless Management, HPE Active Health System, HPE Intelligent Provisioning, and HPE Embedded Remote Support.HPE Insight Control provides advanced management capabilities across the lifecycle of your HPE ProLiant server infrastructure. HPE iLO Advanced, a key component, provides enhanced remote server functions that reduce IT travel costs, while increasing Time-To-Resolution.HPE Insight Online with HPE Insight Remote Support provides 24X7 remote monitoring and anywhere, anytime personalized access to your IT and support status.HPE SmartUpdate reduces deployment time and update complexity by systematically updating server infrastructure in the data center. Includes HPE Smart Update Manager (HPE SUM), and Service Pack for ProLiant (SPP), and other products.
HPE ProLiant DL560 Gen8 - rack-mountable - Xeon E5-4603 2 GHz - 16 GB - no HDD
Server - rack-mountable - administrator password, power-on password, serial port I/O control, 80 PLUS Platinum Plus
Height (Rack Units)
2U
Server Scalability
4-way
2 x Intel Xeon E5-4603 / 2 GHz (Quad-Core)
Processor Main Features
Intel QuickPath Interconnect
Cache Memory
20 MB L3 Cache
Cache Per Processor
10 MB
RAM
16 GB (installed) / 1.5 TB (max) - DDR3 SDRAM - PC3-12800
Storage Controller
RAID (SATA 6Gb/s / SAS 6Gb/s) - PCIe 3.0 x8 (Smart Array P420i)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Matrox G200
GigE
Power Redundancy
Optional
44.55 cm x 74.93 cm x 8.73 cm
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Recommended Use
Small business, corporate business
Product Form Factor
Rack-mountable - 2U
Server Scalability
4-way
Hot-Swap Bays Qty
5
Processor / Chipset
CPU
Intel Xeon E5-4603
Clock Speed
2 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
2
Max CPU Qty
4
CPU Upgradability
Upgradable
Cache Memory
Installed Size
L3 Cache - 20 MB
Cache Per Processor
10 MB
RAM
Installed Size
16 GB / 1.5 TB (max)
DDR3 SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
48 (Total)
Registered, quad channel memory architecture, HP SmartMemory
RAM Supported
PC3-12800 - 768 GB registered , PC3-10600 - 768 GB - low voltage - registered , PC3-10600 - 1536 GB - low voltage - Load-Reduced
Hard Drive
No HDD
Storage Controller
1 x RAID - integrated - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Smart Array P420i
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200
Video Interfaces
VGA
Plug-in card
Interface (Bus) Type
FlexibleLOM
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HP 331FLR
Remote Management Protocol
SNMP, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), ACPI support, PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP)
Bays
5 (total) / 5 (free) x hot-swap 2.5" SFF
Slots
1 (total) / 0 (free) x FlexibleLOM , 48 DIMM 240-pin , 4 (total) / 2 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x8 - half-length, full-height (x4 mode) , 1 (total) / 1 (free) x microSD Card (internal)
1 x serial , 2 x VGA (1 front, 1 rear) , 1 x HPE iLO , 7 x USB 2.0 (2 front, 4 rear, 1 internal) , 4 x LAN (Gigabit Ethernet)
Administrator password, power-on password, serial port I/O control, 80 PLUS Platinum Plus
ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, BSMI CNS 13438
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
1200 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
94%
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris, Citrix XenServer
44.55 cm
74.93 cm
8.73 cm
10 °C
35 °C
10 - 90% (non-condensing)
