HPE HP PROLIANT DL385 G7 2X O6180SE
Quicklinx: 82F3WS00 Mfr#: 636071-421
  • Opteron
As the leading 2P 2U AMD rack server, the ProLiant DL385 G7 is designed with virtualization in mind, yet flexible and expandable to support any business need in many environments from corporate data centers to sophisticated SMBs.
  • Double Down on Performance
    Latest AMD Opteron 6200 Series 16, 12, 8 and 4 Core processors.Integrated network interconnects to free up PCI slots and support more virtual machines.Up to 24 DIMM slots supporting up to 512 GB of DDR3 Memory.
  • The Right Fit
    With up to six available PCI slots, choose from three modular configurations, including high wattage x16, legacy PCI-X, and (2) x8 dual port risers.8 or 16 SFF SAS hard drives with up to 16 TB, or 6 LFF hard drives for up to 18 TB of internal storage.Choose from 460W AC, 750W AC , 1200W AC or -48V DC power supplies, 92% or 94% Efficiency.Embedded Modular SmartArray storage controllers and your choice of cache size and BBWC or FBWC options.
  • Virtual Perfection
    Robust memory and NIC features to support more virtual machines and compute intensive business needs.HP Insight Control tools allows you to manage both physical and virtual IT through a single console.Get virtual machines deployed easily and securely.
  • Focus on Energy Efficiency
    92% and new 94% efficiency power supplies saves energy costs.HP Thermal Logic provides robust power management.
HPE ProLiant DL385 G7 Performance - rack-mountable Opteron 6180 SE 2.5 GHz - 16 GB - no HDD
Server - rack-mountable - administrator password, power-on password, keyboard password, serial port I/O control, quick lock
Height (Rack Units)
2U
Region: Europe
Server Scalability
2-way
2 x AMD Opteron 6180 SE / 2.5 GHz (12-core)
Cache Memory
24 MB L3 Cache
Cache Per Processor
12 MB
RAM
16 GB (installed) / 256 GB (max) - DDR3 SDRAM - Advanced ECC - PC3-10600
Storage Controller
RAID (SATA 3Gb/s / SAS 6Gb/s) - PCIe 2.0 x4 (Smart Array P410i with 1GB FBWC)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
DVD-Writer
Graphics Controller
ATI ES1000
1GbE
Power Redundancy
Software Included
HP Insight Control
44.5 cm x 70 cm x 8.6 cm
20.8 kg
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Recommended Use
Small business, corporate business
Product Form Factor
Rack-mountable - 2U
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
8
Region: Europe
Processor / Chipset
CPU
AMD Opteron 6180 SE
Clock Speed
2.5 GHz
Number of Cores
12-core
64-bit Computing
CPU Qty
2
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
AMD SR5690/SP5100
Cache Memory
Installed Size
L3 Cache - 24 MB
Cache Per Processor
12 MB
RAM
Installed Size
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
24 (Total) / 16 (empty)
Registered
Configuration Features
8 x 2 GB
RAM Supported
PC3-10600 - 256 GB registered , PC3-10600 - 64 GB unbuffered
Hard Drive
No HDD
Storage Controller
1 x RAID - plug-in card - PCIe 2.0 x4
Controller Interface Type
Storage Controller Name
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
Buffer Size
1 GB
Optical Storage
DVD±RW DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
ATI ES1000
Video Interfaces
VGA
Integrated
Interface (Bus) Type
PCI Express x4
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
2 x HP NC382i
Remote Management Controller
Integrated Lights-Out 3
Wake on LAN (WoL), ACPI support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
1 (total) / 1 (free) x PCIe 2.0 x16 - full-length, full-height (x8 mode) , 2 (total) / 1 (free) x PCIe 2.0 x8 - half-length, full-height (x4 mode) , 2 (total) / 0 (free) x CPU , 24 (total) / 16 (free) x DIMM 240-pin
1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x VGA (1 front, 1 rear) , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 4 x USB 2.0 (2 front, 2 rear)
Administrator password, power-on password, keyboard password, serial port I/O control, quick lock
ACPI 2.0, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, BSMI CNS 13438
Power supply
Power Redundancy
Power Redundancy Scheme
1+1
Installed Qty
2
Max Supported Qty
2
Power Provided
750 Watt
Operating System / Software
Software
HP Insight Control
44.5 cm
70 cm
8.6 cm
20.8 kg
10 °C
35 °C
10 - 90%
