Are you constrained by budget, space and IT resources? Yet you need an enterprise-class server for your IT environment? The HP ProLiant DL360e Gen8 Server includes ample performance, storage and I/O features at a low acquisition cost for the value-focused customer. Hyperscale customers can take advantage of the dense 1U design, price-performance, and energy efficiency to scale out as their needs increase. Built-in intelligence simplifies server management, and a proactive service model automates service support, enabling businesses with limited IT resources to focus on more important tasks. The ProLiant DL360e Gen8 Server delivers performance, data security, and energy efficiency, providing an excellent value on your investment.
Essential Features For the IT Needs of Value-Focused Enterprises
The HPE ProLiant DL360e Gen8 Server, with built-in technologies, addresses business requirements at low initial acquisition cost, delivering great value for investment.Supports up to two Intel Xeon E5-2400 v2 processors, offering improved performance, efficiency and security.HPE SmartMemory, with speeds up to 1600 MHz at low voltage, now prevents data loss and downtime with enhanced error handling, while improving performance and power efficiency. Maximum memory supported is 384 GB.Latest HPE Smart Array Controllers are designed to maximize data availability, performance and capacity.Network and I/O scalability are provided by 4x1 GbE network ports and two I/O slots. -
Optimized Design, Efficiency and Scalability for Hyperscale Environments
The HPE ProLiant DL360e Gen8 Server delivers an affordable solution in a dense 1U rack design that enables Hyperscale customers to scale out as their requirements increase.Embedded quad-port NIC, 2 PCIe slots, and 12 DIMM slots provide the internal expansion capabilities needed for distributed computing environments like Hadoop and NoSQL.HPE Common Slot Power Supplies provide 96% server power efficiency to reduce power consumption, while HPE Automated Energy Optimization reclaims space, power, and cooling resources to extend your data center capacity.ENERGY STAR qualified server configurations illustrate a continued commitment to helping customers conserve energy and save money. -
Built-in Innovations that Simplify Management and Free Up Limited IT Resources
With embedded management tools, the HPE ProLiant DL360e Gen8 Server simplifies server management and maintenance tasks, enabling quick and simple deployment (HPE Intelligent Provisioning), system health monitoring (HPE Active Health System), and ease of firmware updates (HPE Smart Update Manager).HPE Smart Storage Administrator provides a single display screen for management and configuration of all HPE Smart Storage products and solutions.User-inspired design features that prevent data loss, reduce downtime, and improve serviceability include HPE SmartDrives, HPE Smart Socket guides, "Easy Install" rail kit options, and tool-less access to components. -
Proactive Service and Support to Redefine Service Experience
The HPE ProLiant DL360e Gen8 Server offers HPE proactive support services, which integrate industry leading performance, uptime, and productivity into a personalized, simplified support experience.HPE Insight Online with HPE Insight Remote Support provides 24x7 remote monitoring and anywhere, anytime personalized access to your IT and support status.Through HPE ServiceOne partners, you get responsive qualified partners to help you plan, manage and deliver solutions spanning the entire IT lifecycle.
- HPE ProLiant DL360e Gen8 Base - rack-mountable - Xeon E5-2407 2.2 GHz - 8 GB - no HDD
- Server - rack-mountable - administrator password, power-on password, serial port I/O control
- Height (Rack Units)
- 1U
- Localisation
- Region: Europe
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2407 / 2.2 GHz (Quad-Core)
- Processor Socket
- LGA1356 Socket
- Processor Main Features
- Intel QuickPath Interconnect, Intel Smart Cache
- Cache Memory
- 10 MB L3 Cache
- Cache Per Processor
- 10 MB
- RAM
- 8 GB (installed) / 192 GB (max) - DDR3 SDRAM - Advanced ECC - PC3-10600
- Storage Controller
- SAS-2 (SATA 6Gb/s / SAS 6Gb/s) - PCIe 2.0 x4 (HP Dynamic Smart Array B320i with 512MB FBWC)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 43.46 cm x 69.9 cm x 4.32 cm
- 13.2 kg
- Limited warranty - parts and labour - 1 year - on-site , Limited warranty - parts - 3 years
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Rack-mountable - 1U
- 2-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 8
- Localisation
- Region: Europe
Processor / Chipset
- CPU
- Intel Xeon E5-2407
- Clock Speed
- 2.2 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1356 Socket
- Chipset Type
- Intel C600
Cache Memory
- Installed Size
- L3 Cache - 10 MB
- 10 MB
RAM
- Installed Size
- 8 GB / 192 GB (max)
- Technology
- Effective Memory Speed
- 1066 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3-10600
- Form Factor
- DIMM 240-pin
- Slots
- 12 (Total) / 10 (empty)
- Registered, low-voltage
- Configuration Features
- 2 x 4 GB
- RAM Supported
- 384 GB Load-Reduced - Advanced ECC , 192 GB registered - Advanced ECC , 96 GB unbuffered - Advanced ECC
Hard Drive
- No HDD
Storage Controller
- 1 x SAS-2 - integrated - PCIe 2.0 x4
- Controller Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Storage Controller Name
- HP Dynamic Smart Array B320i with 512MB FBWC
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
- Buffer Size
- 512 MB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox G200
- Integrated
- Interface (Bus) Type
- PCI Express 2.0 x4
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- HP 366i
- Data Link Protocol
- Remote Management Protocol
- SNMP, IPMI 2.0, SMASH CLP
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1as, IEEE 802.3az
- Bays
- 1 (total) / 1 (free) x external ¦ 8 (total) / 8 (free) x hot-swap 2.5" SFF
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x8 - low-profile (x4 mode) , 1 (total) / 1 (free) x SD card
- 2 x display / video (1 front, 1 rear) , 1 x serial , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 6 x USB 2.0 (2 front, 4 rear)
- Administrator password, power-on password, serial port I/O control
- ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, BSMI CNS 13438
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 460 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Efficiency
- 92%
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris
- 43.46 cm
- 69.9 cm
- 4.32 cm
- 13.2 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
- Sound Emission
- 33 dBA
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.86 |
