Do you need a cost-effective server that can keep pace with your data growth while providing options to manage and deliver performance? The HPE ProLiant DL180 Gen9 Server delivers an optimized 2U server, designed with the right balance of expandability, performance, reliability and manageability all in a new compact chassis, making it the ideal platform for SMBs and Enterprises running the "New Style of IT", applications such as Hadoop, Cloud and mobility applications which need right mix of compute and storage.
Scalability and Performance To Meet the New Standard of Growing Data Center Needs
The HPE ProLiant DL180 Gen9 Server provides ample storage capacity on demand with drive configurations ranging from (4) to (12) Large Form Factor (LFF) or (8) to (16) Small Form Factor (SFF) HPE SmartDrives, with flexibility of LFF non-hot plug (NHP) options at the right economics.It supports up to two Intel Xeon processor E5-2600 v3/v4 processors with up to (12) cores and (16) DIMM slots of HPE DDR4 SmartMemory offering improved performance and efficiency.Comes standard with 2x1GbE and choice of HPE FlexibleLOM or PCIe standup 1GbE or 10GbE Adapters provide you flexibility of networking bandwidth and fabric so you can adapt and grow to changing business needs.Up to six PCIe 3.0 riser slots to support a wide range of GPUs and networking cards offering increased IO bandwidth and seamless expandability.Embedded SATA HPE Dynamic Smart Array B140i Controller for boot and data. Choice of HPE Smart Array Controllers with increased performance, data availability with 12 Gb/s SAS technology or HPE Smart HBAs with reliable high performance SAS connectivity capable of running HBA mode or simple RAID mode. -
High Availability and Efficiency for Dense Storage Applications
The HPE ProLiant DL180 Gen9 Server supports HPE SmartDrive technology which improves serviceability and prevents data loss with features, such as, self-describing LEDs and a Do Not Remove icon.HPE SmartMemory prevents data loss and downtime with enhanced error handling. Support of up to 512 GB max capacity with speeds up to 2133 MHz with up to 14% performance gain.80 PLUS certified entry-level redundant HPE Power Supplies provide up to 92% efficiency which combined with HPE power management features leads to reduction of power consumption.Improved ambient temperature standard with ASHRAE A3 and A4 helps customers reduce cooling expense.ENERGY STAR qualified server configurations illustrate a continued commitment to helping customers conserve energy and save money. -
Agile Infrastructure Management for Accelerating IT Service Delivery
With HPE ProLiant DL180 Gen9 Server, HPE OneView provides infrastructure management for automation simplicity across servers, storage and networking.Online personalized dashboard for converged infrastructure health monitoring and support management with HPE Insight Online.Configure in UEFI boot mode, provision local and remote with Intelligent Provisioning and Scripting Toolkits.Embedded management to deploy, monitor and support your server remotely, out of band with HPE iLO.Optimize firmware and driver updates and reduce downtime with Smart Update, consisting of SUM (Smart Update Manager) and SPP (Service Pack for ProLiant).
- HPE ProLiant DL180 Gen9 - rack-mountable - Xeon E5-2603V3 1.6 GHz - 8 GB - no HDD
- Server - rack-mountable - administrator password, power-on password, serial port I/O control, UEFI BIOS
- Height (Rack Units)
- 2U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2603V3 / 1.6 GHz (6-core)
- Processor Socket
- LGA2011-v3 Socket
- Cache Memory
- 15 MB L3 Cache
- Cache Per Processor
- 15 MB
- RAM
- 8 GB (installed) / 256 GB (max) - DDR4 SDRAM - Advanced ECC - PC4-17000
- Storage Controller
- RAID (SATA 6Gb/s) (HP Dynamic Smart Array B140i)
- Server Storage Bays
- Non-hot-swap 3.5"
- Hard Drive
- No HDD
- Optical Storage
- DVD-Writer
- Graphics Controller
- Matrox G200eH2
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- 44.55 cm x 60.7 cm x 8.75 cm
- 16.59 kg
- Manufacturer Selling Program
- HP Top Value
- Limited warranty - parts - 3 years - response time: next business day , Limited warranty - parts and labour - 1 year - on-site - response time: next business day
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Rack-mountable - 2U
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 2-way
- Front Accessible Bays Qty
- 4
Processor / Chipset
- CPU
- Intel Xeon E5-2603V3
- Clock Speed
- 1.6 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- L3 Cache - 15 MB
- 15 MB
RAM
- Installed Size
- 8 GB / 256 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 16 (Total) / 15 (empty)
- Registered, HP SmartMemory
- Configuration Features
- 1 x 8 GB
- RAM Supported
- PC4-17000 - 256 GB registered - ECC , PC4-17000 - 512 GB Load-Reduced - ECC
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - integrated
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- HP Dynamic Smart Array B140i
- Channel Qty
- 10
- RAID Level
- RAID 0, RAID 1, RAID 5
Optical Storage
- DVD-RW DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox G200eH2
- Video Interfaces
- VGA
- Integrated
- Interface (Bus) Type
- PCI Express 2.0 x2
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- HP NC361i
- Data Link Protocol
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1as, IEEE 802.3az
- Bays
- 1 (total) / 1 (free) x external , 4 (total) / 4 (free) x 3.5" LFF
- Slots
- 2 (total) / 1 (free) x CPU , 16 (total) / 15 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x microSD Card (internal)
- 2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x HPE iLO - RJ-45 , 1 x VGA , 1 x USB 2.0 (1 in front) , 3 x USB 3.0 (2 rear, 1 internal)
- Included Accessories
- HP Easy Install Rails
- Administrator password, power-on password, serial port I/O control, UEFI BIOS
- ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 4943, GB 9254, CNS 14336, CNS 13438
- HP Top Value
- Power supply
- Voltage Required
- Power Provided
- 550 Watt
- Efficiency
- 89%
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris
- 44.55 cm
- 60.7 cm
- 8.75 cm
- 16.59 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
- Sound Emission
- 39 dBA
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
