HPE HP ProLiant DL120 GEN9 E5-2620V4 SFF SVR/TV
Quicklinx: C667WS00 Mfr#: 860175-425
  • Xeon
  • Red Hat Enterprise Linux
Do you need a dense server solution for virtualization, but have difficulty limiting your licensing costs? The HPE ProLiant DL120 Gen9 Server, enterprise class design packed in a dense 1U/1-socket form factor. Offering a combination of performance, redundancy, expandability as compared to the traditional 1P servers, making the DL120 Gen9 Server ideal for small and midsize businesses and Enterprise customers and the growing needs of running virtualization and general purpose workloads.
  • Combination of Performance and Expandability in a Dense Form Factor
    The HPE ProLiant DL120 Gen9 Server supports (1) Intel Xeon E5-2600 v3/v4 or E5-1600 v3/v4 processor offering improved performance and efficiency in a dense 1U chassis.HPE DDR4 SmartMemory prevents data loss and downtime with enhanced error handling. Support of up to 256 GB max capacity with speeds up to 2400 MHz.HPE SmartDrives continue to deliver optimal performance, capacity, and reliability to meet various customer segments and workload requirements at the right economics. Supports up to (4) LFF and (8) SFF 12 Gb/s HDD/SSD options with maximum capacity of up to 40 TB.Up to (3) PCIe 3.0 riser slots to support more IO with networking cards offering increased IO bandwidth and seamless expandability.
  • Cost Optimized 1-Socket Solution for Enterprise Class Workloads
    The HPE ProLiant DL120 Gen9 Server helps reduce virtualization licensing costs with its 1U/1-socket cost optimized design for SMBs and service providers.Embedded with 2x1GbE, up to (3) PCIe slots and choice of HPE FlexibleLOM provide you flexibility of networking bandwidth and fabric so you can adapt and grow to changing business needs.80 PLUS gold certified entry-level redundant HPE Power Supplies provide up to 92% efficiency which combined with HPE power management features leads to reduction of power consumption and expense.Improved ambient temperature standard with ASHRAE A3 support helps customers reduce cooling expense.
  • Agile Infrastructure Management for Accelerating IT Service Delivery
    With HPE ProLiant DL120 Gen9 Server, HPE OneView provides infrastructure management for automation simplicity across servers, storage and networking.Online personalized dashboard for converged infrastructure health monitoring and support management with HPE Insight Online.Configure in Unified Extensible Firmware Interface (UEFI) boot mode, provision local and remote with Intelligent Provisioning and Scripting Toolkits or RESTful Interface Tool.Embedded management to deploy, monitor and support your server remotely, out of band with HPE iLO.Optimize firmware and driver updates and reduce downtime with Smart Update, consisting of SUM (Smart Update Manager) and SPP (Service Pack for ProLiant).
  • Energy Efficiency by Design
    80 PLUS gold certified entry-level redundant HPE Power Supplies provide up to 92% efficiency which combined with HPE power management features leads to reduction of power consumption and expense.Improved ambient temperature standard with ASHRAE A3 helps customers reduce cooling expense.
HPE ProLiant DL120 Gen9 - rack-mountable Xeon E5-2620V4 2.1 GHz - 8 GB - no HDD
Server - rack-mountable
Height (Rack Units)
1U
Server Scalability
1-way
1 x Intel Xeon E5-2620V4 / 2.1 GHz (up to 3 GHz, (8-core)
Cache Memory
20 MB L3 Cache
Cache Per Processor
20 MB
RAM
8 GB (installed) / 128 GB (max) - DDR4 SDRAM - Advanced ECC - PC4-17000
Storage Controller
RAID (SATA 6Gb/s) (HP Dynamic Smart Array B140i)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Matrox G200eH2
1GbE
43.46 cm x 60.76 cm x 4.29 cm
9 kg
Manufacturer Selling Program
HP Top Value
Limited warranty - parts - 3 years , Limited warranty - parts and labour - 1 year - on-site
Server
Product Form Factor
Rack-mountable - 1U
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Server Scalability
1-way
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Clock Speed
2.1 GHz
Max Turbo Speed
3 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Cache Memory
Installed Size
L3 Cache - 20 MB
Cache Per Processor
20 MB
RAM
Installed Size
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
8 (Total) / 7 (empty)
Registered, Online Spare Memory, quad channel memory architecture, HP SmartMemory
Configuration Features
1 x 8 GB
RAM Supported
PC4-17000 - 128 GB registered , PC4-17000 - 256 GB Load-Reduced
Hard Drive
No HDD
Storage Controller
1 x RAID
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
Channel Qty
10
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Matrox G200eH2
Video Interfaces
VGA
Interface (Bus) Type
PCI Express 2.0 x2
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
HP NC361i
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1as, IEEE 802.3az
Bays
8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
1 (total) / 0 (free) x CPU , 8 (total) / 7 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 0 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x FlexibleLOM (x8 mode) , 1 (total) / 1 (free) x microSD Card (internal)
2 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x USB 2.0 (1 in front) , 3 x USB 3.0 (2 rear, 1 internal)
HPE Easy Install Rails
ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 9254, ASHRAE, CNS 13438
HP Top Value
Power supply
Power Provided
900 watt
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
43.46 cm
60.76 cm
4.29 cm
9 kg
10 °C
35 °C
8 - 90% (non-condensing)
C667 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.16
