The HP ProLiant BL685c G7 Server Blade delivers scale-up, dense, cost-effective 4-socket performance for high-density virtualization and compute-intensive database environments. With up to 64 cores in a single blade and 32 DDR3 registered DIMM slots offering an impressive 1TB memory footprint, these servers are the ideal choice for the most demanding applications. Delivering over 80 Gb of I/O bandwidth with four embedded HP NC551i Dual Port 10Gb FlexFabric Converged Network Adapter ports and three I/O expansion slots, this is the ideal 4-socket blade for enterprise data centers that demand cost-effective performance and scalability.
Multicore Scalability-Up to 64 Cores
Up to four 4-, 8-, 12- or 16-core AMD Opteron processors, delivering outstanding compute power for high-density virtualization and compute-intensive database environments.High core count processors enable scaling of VM density for greater consolidation and increased performance with multiple cores per VM for more robust virtualization configurations. -
Cost Effective with up to 1 TB of Memory and I/O Bandwidth over 80 Gb
Economical blade design, for greater flexibility and lower TCO, reduces the amount of hardware required for the same performance.Up to 1 TB of DDR3 Registered DIMMs with Advanced ECC enables a large memory footprint for demanding memory intensive applications.Two embedded HP NC551i Dual Port FlexFabric 10Gb Converged Network Adapters deliver bandwidth for network intensive applications with Up To sixteen (16) connections to network and storage.Lower your infrastructure costs and simplify management by converging LAN and SAN traffic over the same flexible connection.Divide and fine-tune network and storage bandwidth to match application requirements with protocol offload for TCP/IP, FCoE, and iSCSI. -
Industry-Leading Infrastructure Management for Virtual and Physical Servers
Deploy servers quickly, proactively manage virtual or physical server health, and reduce power consumption with HP Insight Control.Save time and conserve valuable IT resources by simplifying remote management with HP Integrated Lights-Out 3 (iLO 3).Achieve agility through Cloud Infrastructure Management software with HP Matrix Operating Environment.
- HPE ProLiant BL685c G7 - blade - Opteron 6344 2.6 GHz - 64 GB - no HDD
- Server - blade - administrator password, power-on password, USB port control
- Server Scalability
- 4-way
- Processor
- 4 x AMD Opteron 6344 / 2.6 GHz (3.2 GHz) (12-core)
- Cache Memory
- 64 MB L3 Cache
- Cache Per Processor
- 16 MB
- RAM
- 64 GB (installed) / 512 GB (max) - DDR3 SDRAM - PC3-10600
- Storage Controller
- SAS-2 (SATA 3Gb/s / SAS 6Gb/s) - PCIe 2.0 x4 (Smart Array P410i with 1GB FBWC)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- ATI ES1000
- Networking
- GigE, 10 GigE
- 5.56 cm x 50.95 cm x 36.63 cm
- 8.7 kg
- Limited warranty - parts and labour - 3 years - on-site
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Blade
- 4-way
- Hot-Swap Bays Qty
- 2
Processor / Chipset
- CPU
- AMD Opteron 6344
- Clock Speed
- 2.6 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- 12-core
- CPU Qty
- 4
- Max CPU Qty
- 4
- CPU Upgradability
- Upgradable
- Chipset Type
- AMD SR5690/SP5100
Cache Memory
- Installed Size
- L3 Cache - 64 MB
- 16 MB
RAM
- Installed Size
- 64 GB / 512 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1333 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3-10600
- Form Factor
- DIMM 240-pin
- Slots
- 32 (Total) / 16 (empty)
- Registered
- Configuration Features
- 16 x 4 GB
- RAM Supported
- PC3-12800 - 512 GB registered , PC3-8500 - 1 TB registered , PC3-10600 - 512 GB - low voltage - registered
Hard Drive
- No HDD
Storage Controller
- 1 x SAS-2 - integrated - PCIe 2.0 x4
- Controller Interface Type
- SATA 3Gb/s / SAS 6Gb/s
- Storage Controller Name
- Smart Array P410i with 1GB FBWC
- RAID Level
- RAID 0, RAID 1
- Buffer Size
- 1 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- ATI ES1000
- Integrated
- Interface (Bus) Type
- PCI Express 2.0 x8
- Ethernet Ports
- 4 x 10 Gigabit Ethernet
- Ethernet Controller
- 2 x HP NC551i
- Data Link Protocol
- Gigabit Ethernet, 10 Gigabit Ethernet
- Remote Management Controller
- Integrated Lights-Out 3
- Wake on LAN (WoL)
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ap
- Bays
- 2 (total) / 2 (free) x hot-swap 2.5" SFF
- Slots
- 4 (total) / 0 (free) x CPU , 32 (total) / 16 (free) x DIMM 240-pin , 3 (total) / 3 (free) x expansion slot , 1 (total) / 1 (free) x microSD Card
- 1 x HPE iLO , 4 x LAN (10Gigabit Ethernet) , 1 x USB (1 internal)
- Administrator password, power-on password, USB port control
- ACPI 2.0, WEEE
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris, Citrix XenServer
- 5.56 cm
- 50.95 cm
- 36.63 cm
- 8.7 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
