HPE HP ProCurve 10-GbE SFP+ LRM SFP+ Transceiver Module
Quicklinx: 7YZ1WS00 Mfr#: J9152A
Type: Modules
£632.42 ex VAT
£758.90 inc VAT
A 10-Gigabit transceiver in SFP+ form-factor that supports the 10-Gigabit LRM standard, for 10-Gigabit connectivity up to 220 m on legacy multimode fiber.
  • Warranty and support
    ProCurve Lifetime Warranty: for as long as you own the product, with next-business-day advance replacement (available in most countries).
HPE - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-LRM
Optical Wave Length
1310 nm
10GbE
Max Transfer Distance
220 m
1.4 cm x 5.6 cm x 1.2 cm
HP SFP+ zl Module Rack Shippable; HPE 2-Port SFP+/ 2-Port CX4 10GbE yl Module, 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch, SFP+ zl; Modular Smart Array P2000 G3 10GbE iSCSI Dual Controller SFF Array System, P2000 G3 iSCSI Dual Controller SFF Bundle; HPE Aruba 5406 zl
Plug-in module
Wired
Cabling Type
10GBase-LRM
10GbE
Optical Wave Length
1310 nm
220 m
IEEE 802.3aq
1 x Ethernet 10GBase-LRM - LC multi-mode
Compatible Slots
1 x SFP+
1.4 cm
5.6 cm
1.2 cm
70 °C
HP SFP+ zl Module Rack Shippable , HPE 2-Port SFP+/ 2-Port CX4 10GbE yl Module, 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch, SFP+ zl , HPE Modular Smart Array P2000 G3 10GbE iSCSI Dual Controller SFF Array System, P2000 G3 iSCSI Dual Controller SFF Bundle , HPE Aruba 5406 zl
Type: Modules
Brand: HPE
Price Range Ex VAT: £500 - £750
