HPE HP PL DL380 G7 E5649 2.53GHZ 6-CORE 1P 6
Quicklinx: 7DPGWS00 Mfr#: 633405-421
  • Xeon
  • Red Hat Enterprise Linux
The HP ProLiant DL380 G7 Server continues to deliver on its heritage of engineering excellence with increased flexibility and performance, enterprise-class uptime and HP Insight Control manageability, 2 socket Intel Xeon performance, and 2U density for a variety of applications.
  • Increased Performance and Durability for Demanding Scale-Out Applications
    Intel Xeon Processors 5600 series offers higher performance, better power efficiency, and more adaptability with: Intel QuickPath, Integrated Memory Controller, Turbo Boost, Intelligent Power Technologies and Trusted Execution Technology.Up to 384 GB Registered Memory DIMMS (up to 48 GB Unbuffered): Memory intensive applications benefit from memory buffers, faster memory speeds, 4:1 memory interleaving and larger memory capacity.Advanced ECC memory corrects 4bit memory errors that occur within a single DRAM chip on the DIMM. Mirrored memory protection against uncorrectable memory errors without degrading performance of the memory system. Online Memory Spare adds protection from unscheduled downtime.Complete data protection with embedded Smart Array RAID controller, transportable battery-backed write cache and RAID 6 options. Write cache improves disk performance.Serial Attached SCSI (SAS): With up to sixteen (16) SAS drives and new embedded Smart Array RAID controllers, you get quicker access to data and increase storage bandwidth for cutting edge storage performance.
  • Smart, Flexible Systems Ready for Complex, Dynamic Environments
    Insight Control - essential infrastructure management that speeds server deployment, proactively manages health, optimizes power management, and offers control from anywhere – available standard on Performance models.Integrated Lights-Out (iLO) allows powerful, hardware-based remote administration and control from a standard web browser to conserve valuable IT staff resources.Server configuration and deployment is simplified with tools like SmartStart, Rapid Deployment Pack, PXE, and ROM-Based Setup Utility (RBSU).Integrated VMware and XenServer virtualization technology; internal USB and SD slot.System Insight Display: A rugged slide-out system diagnostics display saves administrators time with easy to find trouble shooting information at the front of the server.
  • Energy Efficiency Leadership
    Delivering more power for your needs with the highest efficiency in the industry, as seen by meeting Climate Savers Computing Gold, 80PLUS Gold, and setting the standards for Energy Star for Servers compliance.Right-Sized ProLiant power supplies from 460 Watts at 92% efficiency, 750 Watts at 92% efficiency, to 1200 Watts at 94% efficiency. Be sure to use the HPE Power Calculator for selecting the right size power supply.HPE unique Thermal Logic Technologies provide intelligent power & cooling with "Sea of Sensors" that manage and adjust power and cooling throughout the server to provide continuous peak performance and efficient cooling.Improve your capacity up to 3x with Insight Control and Dynamic Power Capping. Dynamic Power Capping allows you to cap the servers power use level, without impacting performance and still fully protecting the Circuit Breakers in the rack.
  • Engineered for Reliability and Ease of Ownership
    Clean, tool-free, mechanical design enhances reliability and simplifies configuration and maintenance with tool-free, modular components, hot plug redundancy features for fast maintenance, and minimal cables for easy access to components.With universal tool-free sliding rails the DL380 G7 is quick to install and quick release levers allow for fast server access. An ambidextrous cable management arm option provides cabling flexibility and management for quick access to the server.The focus on Server Commonality increases IT productivity and manageability with universal drives, Smart Array Controllers, and common power supplies and components to simplify spare parts inventories.ROM based configuration and management features increase uptime and simplify configuration and independent health monitoring.
HPE ProLiant DL380 G7 Base - rack-mountable Xeon E5649 2.53 GHz - 6 GB - no HDD
Server - rack-mountable - administrator password, power-on password, keyboard password, serial port I/O control, quick lock
Height (Rack Units)
2U
Region: Europe
Server Scalability
2-way
1 x Intel Xeon E5649 / 2.53 GHz (up to 2.93 GHz, (6-core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology
Cache Memory
12 MB L3 Cache
Cache Per Processor
12 MB
RAM
6 GB (installed) / 144 GB (max) - DDR3 SDRAM - PC3-10600
Storage Controller
RAID (SATA 3Gb/s / SAS 6Gb/s) - PCIe 2.0 x4 (Smart Array P410i)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
ATI ES1000
Video Memory
64 MB
1GbE
Power Redundancy
Optional
44.5 cm x 69.2 cm x 8.6 cm
21.5 kg
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Recommended Use
Small business, corporate business
Product Form Factor
Rack-mountable - 2U
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
8
Region: Europe
Processor / Chipset
CPU
Intel Xeon E5649
Clock Speed
2.53 GHz
Max Turbo Speed
2.93 GHz
Number of Cores
6-core
64-bit Computing
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel 5520
Cache Memory
Installed Size
L3 Cache - 12 MB
Cache Per Processor
12 MB
RAM
Installed Size
DDR3 SDRAM
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
18 (Total) / 15 (empty)
Registered
Configuration Features
3 x 2 GB
RAM Supported
PC3-8500 - 192 GB registered , PC3-10600 - 144 GB registered , PC3-10600 - 48 GB unbuffered
Hard Drive
No HDD
Storage Controller
1 x RAID - integrated - PCIe 2.0 x4
Controller Interface Type
Storage Controller Name
Smart Array P410i
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
Buffer Size
256 MB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
ATI ES1000
Video Memory
64 MB
Video Interfaces
VGA
Integrated
Interface (Bus) Type
PCI Express x4
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
2 x HP NC382i
Remote Management Controller
Integrated Lights-Out 3
Wake on LAN (WoL), ACPI support, PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP)
Bays
1 (total) / 1 (free) x external 5.25" Slim Line , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
1 (total) / 1 (free) x PCIe 2.0 x16 - full-length, full-height (x8 mode) , 2 (total) / 2 (free) x PCIe 2.0 x8 - half-length, full-height (x4 mode) , 18 (total) / 15 (free) x DIMM 240-pin , 2 (total) / 1 (free) x CPU
1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial , 2 x VGA (1 front, 1 rear) , 4 x USB (2 front, 2 rear) , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO
Administrator password, power-on password, keyboard password, serial port I/O control, quick lock
ACPI 2.0
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
460 Watt
80 PLUS Certification
80 PLUS Gold
Efficiency
92%
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Enterprise Linux
44.5 cm
69.2 cm
8.6 cm
21.5 kg
10 °C
35 °C
10 - 90%
