HPE HP MSL4048 0-Drive Tape Library
Quicklinx: 9612WS00 Mfr#: AK381A
The HPE StoreEver MSL Tape Libraries meet demanding storage requirement of businesses needing unattended tape backup, disaster recovery, or low cost long-term archive capability. The MSL Libraries offer a broad choice of storage capacities and technology including LTO-7, LTO-6, LTO-5 or LTO-4 Ultrium tape drives. Web-based remote management makes the MSL Libraries easily managed from across the room or across the globe. Quickly manage the tape media both in and out of the library with the standard bar code reader, configurable mail slots, and multiple 12-slot removable magazines. Protect important business data from unauthorized access with several data encryption options. MSL library investment protection and uncertain data growth are easily managed within the MSL library portfolio. Quickly increase capacity and/or performance with tool-free drive upgrades in the MSL2024 or 4048, or move tape drive kits to the MSL6480 for library scalability and additional enterprise class features.
  • Easy to Manage and Use
    HPE MSL2024 and 4048 Tape Libraries allow you to manage, configure and use the library from across the room or across the globe with the HPE unique web-based remote management and diagnostics. Manage multiple HPE StoreEver libraries from a single pane with Command View for Tape Libraries.HPE StoreEver MSL2024 and 4048 Tape Libraries easily manage your media both in or out of the tape library with a standard bar code reader and multiple 12-slot removable magazines.Proactively monitor utilization, operational performance, and overall life and health of the library, drives and media with HPE TapeAssure Advanced Software. TapeAssure Advanced provides an intuitive, easy to use dashboard, and advance analytics for predictive analysis.
  • Protection and Flexibility
    HPE StoreEver MSL Tape Libraries offer various interface options for maximum flexibility when installing the tape library into a SAS or fibre channel SAN environment.HPE StoreEver MSL2024 and 4048 Tape Libraries offer a wide range of capacity points from 9.6 TB to 1440 TB of compressed storage capacity in a variety of rack ready form factors.Protect critical business data with MSL encryption options that span from small business to the datacenter. Encryption is available on LTO-8 LTO-7, LTO-6 or LTO-5 tape drives and provides the highest level of security to protect confidential information and address compliance regulations.Increase capacity and/or performance with tool-free drive upgrade kits.
  • Proven Reliability
    HPE StoreEver MSL2024 and 4048 Tape Libraries work with industry-leading servers, operating systems and backup software. See DAPR compatibility matrix for more information.Long term data archiving with a specified 30-year media shelf life in normal ambient conditions.
HPE StoreEver MSL4048 - tape library - no tape drives
Tape library
Enclosure Type
Rack-mountable - 4U
Removable Media Capacity
48
Max Supported Drives
4
Supported Tape Drives
LTO Ultrium 4, LTO Ultrium 5, LTO Ultrium 6
Key Features
Barcode reader, encryption
48 cm x 80.6 cm x 17.5 cm
21.4 kg
Storage Removable
No tape drives
1-year warranty
ProLiant DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance
Tape library - no tape drives
Enclosure Type
Rack-mountable - 4U
48
4
Key Features
Built-in Devices
Led panel, status LCD
48 cm
80.6 cm
17.5 cm
21.4 kg
Storage Removable
No tape drives
1 x SAS , 1 x (management) - RJ-45 , 1 x USB 2.0 (management)
1 x network cable
Rack Mounting Kit
Included
MTBF
100,000 hour(s)
MSBF
2,000,000
RoHS, AES-256
Power supply
312 Watt
Limited warranty - parts - 1 year - response time: next business day
10 °C
35 °C
20 - 80% (non-condensing)
HPE ProLiant DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance
9612 HPE Ultrium Universal Cleaning Cartridge - LTO Ultrium - orange - cleaning cartridge In Stock £35.59
