HPE HP ML10v2 G3240 NHP Entry UK Server
Quicklinx: BNPTWS00 Mfr#: 814483-031
  • Pentium
  • Red Hat Enterprise Linux
Are you looking for a standalone server that is both affordable and flexible for your small business? The HP ProLiant ML10 v2 Server is a single-socket 4U tower server, delivering excellent value that small businesses require to run a small network environment. It provides entry-level businesses with an affordable server that can be used as a standalone tower configuration. It is outstanding for businesses looking for a server with low acquisition cost, increased connectivity slots for storage and networking, optimized compute with built-in reliability, and agile management.
  • Low Acquisition Cost for the Budget Conscious
    The HPE ProLiant ML10 v2 Server offers the right server technology for small businesses looking for just the right performance and features at an affordable price.Embedded HPE Integrated Lights-Out (iLO 4) remote and out of band management allows network administrators to easily check and update servers remotely, reducing any offsite travel expenses.Pre-Installed with 2x1GbE and up to four (4) PCIe slots to adapt and grow to meet changing business needs.
  • Increased Connectivity Slots for Storage and Networking
    The HPE ProLiant ML10 v2 Server design allows for easy installation and convenient expansion to meet business needs, with support for up to six (6) large form factor (LFF) hard disk drives, four (4) USB ports, and four (4) I/O slots.Designed with two (2) 2x1Gbe NIC ports for better networking experience and higher availability.The ML10 v2 Server delivers many years of expandability and operational efficiency for businesses at a desktop price.
  • Optimal Computing with Built-in Reliability
    The HPE ProLiant ML10 v2 Server comes standard with four (4) DIMM slots for Error Correcting Code (ECC) memory that protects businesses data from data loss and unplanned system downtime.The HPE Dynamic Smart Array B120i provides an embedded 6Gb/s SATA controller RAID solution for customers who use SATA drives for both boot and data to protect critical data from loss of a disk drive.Server class technology allows for 24x7 business operation, offering higher reliability and longer lifecycle.It supports the Intel Xeon E3-1200 v3 processor in a 4U chassis offering improved performance and efficiency.Offered in a large server chassis size to allow for maximum air flow helping to reduce component failure.
  • Agile Management with Essential Simplicity and Automation
    The HPE ProLiant ML10 v2 Server offers essential management for control, and optimization of HPE ProLiant servers with HPE Insight Control.Online personalized dashboard for Converged Infrastructure (CI) for support management with HPE Insight Online.Optimize firmware and driver updates and reduce downtime with HPE Smart Update, consisting of HPE Smart Update Manger (SUM) and Service Pack for ProLiant (SPP).
HPE ProLiant ML10 v2 Entry - micro tower - Pentium G3240 3.1 GHz - 4 GB - no HDD
Server - micro tower - administrator password, power-on password
Region: United Kingdom
Server Scalability
1-way
1 x Intel Pentium G3240 / 3.1 GHz (Dual-Core)
Processor Socket
LGA1150 Socket
Cache Memory
3 MB L3 Cache
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s) (HP Dynamic Smart Array B120i)
Server Storage Bays
Non-hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Matrox G200
GigE
17.5 cm x 47.52 cm x 36.82 cm
10.8 kg
Limited warranty - parts - 1 year
Server
Product Form Factor
Micro tower
Server Scalability
1-way
Internal Bays Qty
4
Front Accessible Bays Qty
2
Processor / Chipset
CPU
Intel Pentium G3240
Clock Speed
3.1 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1150 Socket
Chipset Type
Intel C222
Cache Memory
Installed Size
L3 Cache - 3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1333 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, HP SmartMemory
Configuration Features
1 x 4 GB
RAM Supported
PC3-12800 - 32 GB unbuffered - ECC , PC3-12800 - 32 GB - low voltage - unbuffered - ECC
Hard Drive
No HDD
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Matrox G200
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
HP 332i
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3az
Bays
4 (total) / 4 (free) x internal 3.5" LFF , 2 (total) / 2 (free) x external 5.25" x 1/2H
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x8 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x8 - full-length, full-height (x1 mode) , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height (x1 mode)
1 x VGA , 2 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 4 x USB 3.0 (2 front, 2 rear)
Administrator password, power-on password
ACPI 2.0b, FCC Class B certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 9254, CNS 13438
Power supply
Power Provided
350 Watt
Efficiency
85%
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Canonical Ubuntu
17.5 cm
47.52 cm
36.82 cm
10.8 kg
10 - 90% (non-condensing)
Sound Emission
27 dBA
BNPT C2G 2m USB 2.0 A/B Cable - Black In Stock £4.16
