Ideal for small businesses, the cost-effective HPE M210 802.11n Access Point Series, supports standalone operation or can be "clustered" for simplified administration of up to 4 access points where more robust coverage is required. These dual-band, single-radio devices support high-speed wireless networking at 5GHz or 2.4GHz to provide a better user experience and faster delivery of mobile applications. Clustering technology propagates wireless network configurations across all access points for consistent security and uninterrupted, wireless client roaming.
Simplifies Wireless Networks for Small Businesses
The HPE M210 802.11n Access Point Series includes simple clustering technology which reduces complexity and the need for additional hardware. A quick setup wizard gets you up and running very quickly with five common deployment scenarios to best match your environment. -
Keeps Your Business up and Running with Safe Wireless Access
The HPE M210 802.11n Access Point Series significantly reduces the risk of downtime from human error with clustering technology.It keeps your wireless network traffic safe with the latest in Wi-Fi security including WPA and WPA2.Secures data integrity of wireless traffic with Advanced Encryption Standard (AES) or Temporal Key Integrity Protocol (TKIP).The HPE M210 802.11n Access Point Series offers up to 4 VLANs to permit traffic segmentation on the network. -
Delivers a Better User Experience and Improved Performance
The HPE M210 802.11n Access Point Series provides a single-radio device that supports high-speed wireless networking at either 5GHz or 2.4GHz.When clustered, each HPE M210 Access Point automatically selects the best channel for operation, reducing AP channel planning while periodically reassessing AP channel mapping for channel optimization. -
Lowers Total Cost of Ownership (TCO)
The HPE M210 802.11n Access Point Series are covered by a Limited Lifetime Warranty.The HPE M210 clustering technology makes ongoing network changes and maintenance simple, reducing the time spent on administrative tasks.
- HPE M210 (WW) - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Maximum number of configured SSIDs: 4 , VLANs supported: 4
- Power Over Ethernet (PoE) Supported
- PoE
- 19.35 cm x 12.7 cm x 3.81 cm
- 340 g
- Limited lifetime warranty
- 19.35 cm
- 12.7 cm
- 3.81 cm
- 340 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Remote Management Protocol
- HTTP, HTTPS
- Communication Mode
- Half-duplex, full-duplex
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Auto-uplink (auto MDI/MDI-X), IPv6 support, Wireless Distribution System (WDS) support, MIMO technology, Spanning Tree Protocol (STP) support
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, SSL, TKIP, WPA, WPA2
- Authentication Method
- RADIUS
- IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- 1 x 1000Base-T - RJ-45
- IEC 60950-1 Second Edition, EN 300 328, EN 50385
- PoE
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 15 - 95% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
