Your basket is empty
HPE HP LTO-3 Ultrium 920 SAS External Tape Drive
Quicklinx: 9850WS00 Mfr#: E7W42A
Type: LTO Ultrium
Native Capacity: 400GB
£666.61 ex VAT
£799.93 inc VAT
HPE StoreEver LTO Ultrium Tape Drives represent seven-generations of LTO technology capable of storing up to 15 TB per cartridge, with HPE TapeAssure for manageability, hardware data encryption, HPE StoreOpen with LTFS for ease of use at an unprecedented performance. With HPE TapeAssure customers can be confident that their data is safe by monitoring drive and media utilization, operational performance and life/health information for drive and media. Data hardware encryption using AES 256-bit provides easy-to-enable security to protect the most sensitive data and prevent unauthorized access of tape cartridges. Linear Tape File System (LTFS) is an open format for storing data on tape that makes LTO generation 5 and later tapes self-describing and file-based. Capable of data transfer rates up to 300 MB/sec native, HPE's Data Rate Matching further optimizes performance by matching host system speed to keep drives streaming, thus enabling the fastest tape performance.
HPE StoreEver LTO-3 Ultrium 920 - tape drive - LTO Ultrium - SAS
Tape drive
Recording Standard
LTO Ultrium 3
Enclosure Type
External
Interface Type
SAS
22.3 cm x 29.5 cm x 7.7 cm
4.65 kg
Storage Removable
LTO Ultrium
Storage Removable Capacity
400 GB (native) / 800 GB (compressed)
Supported Tape Cartridges (Read and Write)
Ultrium 2, Ultrium 3
Data Transfer Rate (native)
60 MBps (216 GBph)
Data Transfer Rate (compressed)
120 MBps (432 GBph)
Manufacturer Selling Program
HP Top Value
Tape drive - LTO Ultrium
Recording Standard
LTO Ultrium 3
Enclosure Type
External
Interface Type
SAS
22.3 cm
29.5 cm
7.7 cm
4.65 kg
Storage Removable
LTO Ultrium
Recording Standard
60 MBps (216 GBph)
120 MBps (432 GBph)
Average Seek / Access Time
64 sec
Buffer Size
64 MB
1 x SAS - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088)
Media Included Qty
5
1 x SAS cable
MTBF
250,000 hour(s)
TUV, VCCI, C-Tick, BSMI, EN 60950, NOM, RRL, IEC 60950, CSA 22.2 No. 60950, CB, FCC CFR47 Part 15, RoHS2
HP Top Value
Software Included
HP Library and Tape Tools
10 °C
20 - 80% (non-condensing)
9850 HPE HP Ultrium Universal Cleaning Cartridge - LTO Ultrium - orange - cleaning cartridge In Stock £88.68
9850 HPE HP - LTO Ultrium 2 - 200 GB / 400 GB - red - storage media In Stock £33.99
Type: LTO Ultrium
Brand: HPE
Price Range Ex VAT: 500 - 750
