HPE HP LCD8500 KVM Console 18.51"
Quicklinx: BH2CWS00 Mfr#: AF631A
Hurry, only 2 left in stock!
£1,603.94 ex VAT
£1,924.72 inc VAT
Need the latest in KVM technology to manage the servers in your rack? HP KVM Console Kits provide ultra-dense, high-performance KVM consoles that combine both the rack display panel and keyboard with touch pad in a 1U form factor. The 1U rackmount form factor allows for a KVM console switch to be mounted directly behind it. The HP LCD8500 1U Rackmount Console Kit with 18.5-inch WXGA TFT LCD brightview display supports most common video resolutions, up to 1600 x 1200 at 60 to 75 Hz refresh rates. The LCD8500 1U Rackmount Console Kit features a new silver enclosure making identification in the rack much easier. The rackmount keyboard includes a three-button touch pad with four (4) scroll keys and Windows shortcut keys. The LCD8500 1U Rackmount Console Kit also includes a new Lid Switch display management feature that shuts off the display backlight when the console is closed and repowers to its current state when opened again, helping to prolong the life of the display panel.
  • Ultra-Dense, High-Performance KVM Console Display and Keyboard
    HPE Enterprise LCD Consoles combine the rack display panel and keyboard with touch pad in a 1U form factor that allows you to mount a KVM console switch directly behind it saving you space.Features an 18.5-inch WXGA TFT LCD Brightview display that supports most common video resolutions, from 800 x 600 through 1600 x 1200 at 60 to 75 Hz refresh rates.Active Matrix TFT LCD display guarantees a flicker-free picture that is sharper in focus than a CRT monitor.Includes two (2) front side USB pass-through ports for use with KVM Console Switches that support virtual media.
  • Advanced, Ergonomic Design
    Features a silver colored enclosure making identification in the rack much easier.Includes a three-button touch pad, four (4) scroll keys, and Windows shortcut keys.Lid Switch display management feature shuts off the display backlight when the console is closed and repowers to its current state when opened again, helping to prolong the life of the display panel.Tool-less rails for rack installation are included with each console kit allowing for quick and easy installation within minutes.
HPE LCD8500 - KVM console - 18.51"
KVM Switch
USB
Keyboard, touchpad
Native Resolution
1600 x 1200 at 60 Hz
Brightness
187 cd/m²
Contrast Ratio
700:1
Response Time
16 ms
Voltage
Silver
43.61 cm x 43.3 cm x 4.23 cm
Height (Rack Units)
1U
5.2 kg
WEEE
3-year warranty
ProLiant DL120 Gen9, DL160 Gen8, DL160 Gen9, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360e Gen8, DL360p Gen8, DL380 Gen9, DL380e Gen8, DL380p Gen8, DL580 Gen9, DL60 Gen9, DL80 Gen9, MicroServer Gen8, ML110 Gen9, ML150 Gen9, ML310e Gen8, ML350e Gen8
Display Type
KVM console / TFT active matrix
Diagonal Size
18.51"
Native Resolution
Brightness
187 cd/m²
Contrast Ratio
700:1
Response Time
16 ms
Controls & Adjustments
Brightness, contrast
OSD Languages
Chinese (simplified), English, German, French, Italian, Spanish, Japanese
Silver
Height (Rack Units)
1U
5.2 kg
Input
Keyboard, touchpad
KVM
Keyboard / Mouse Interface
USB
English keyboard layout
2 x USB
WEEE
Input Voltage
Power Consumption (Typical)
36 Watt
Limited warranty - parts - 3 years
50 °C
10 - 90% (non-condensing)
HPE ProLiant DL120 Gen9, DL120 Gen9 Entry, DL160 Gen8, DL160 Gen8 Base, DL160 Gen8 Entry, DL160 Gen8 Performance, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL160 Gen9 Performance, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL20 Gen9 Entry, DL20 Gen9 Performance, DL320e Gen8 v2 Base, DL320e Gen8 v2 Entry, DL320e Gen8 v2 Performance, DL360e Gen8, DL360e Gen8 Base, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL380e Gen8, DL380e Gen8 Base, DL380e Gen8 Entry, DL380e Gen8 High Performance, DL380e Gen8 Storage, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Performance, DL380p Gen8 Special, DL580 Gen9, DL580 Gen9 Base, DL580 Gen9 High Performance, DL580 Gen9 SAP HANA Scale-out Base Configuration, DL580 Gen9 SAP HANA Scale-up Base Configuration, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, MicroServer Gen8, MicroServer Gen8 Base, MicroServer Gen8 Entry, MicroServer Gen8 Performance, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML150 Gen9, ML150 Gen9 Base, ML150 Gen9 Entry, ML150 Gen9 Performance, ML310e Gen8, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 v2, ML350e Gen8 v2 Base, ML350e Gen8 v2 Entry
