A 10-Gigabit transceiver in SFP+ form-factor that supports the 10-Gigabit SR standard, providing 10-Gigabit connectivity up to 300m on multimode fiber.
 - Intel - SFP+ transceiver module - 10GbE
 - SFP+ transceiver module - LC
- Form Factor
 - Plug-in module
- Cabling Type
 - 10GBase-SR
- Data Transfer Rate
 - 10 Gbps
- Optical Wave Length
 - 850 nm
- Data Link Protocol
 - 10GbE
 - 1.38 cm x 5.57 cm x 1.19 cm
- Designed For
 - Workstation Z2 G4, Z2 G5, Z2 G8, Z220, Z230, Z420, Z620, Z820
- Form Factor
 - Plug-in module
- Connectivity Technology
 - Wired
- Cabling Type
 - 10GBase-SR
 - 10GbE
 - 10 Gbps
 - 850 nm
 - IEEE 802.3ae
 - 1 x Ethernet 10GBase-SR - LC
- Compatible Slots
 - 1 x SFP+
 - 1.38 cm
 - 5.57 cm
 - 1.19 cm
- Designed For
 - HP Workstation Z2 G4, Z2 G5, Z2 G8, Z220, Z230, Z420, Z620, Z820
