HPE 1.8TB 12G SAS 10K 2.5" SC 512e HDD
Quicklinx: BLKCWS00 Mfr#: 791034-B21
Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
  • Performance and Reliability for Multiple Application Environments
    HPE Server Enterprise Hard Drives are ideal for transaction processing, database applications, big data analytics and high-performance computing.Broad portfolio of optimized solutions provide up to 1.8 TB of storage in a smaller footprint.Efficient drives for power and space constrained datacenters.Latest 12G SAS interface for increased performance.
HPE Enterprise - hard drive - 1.8 TB - SAS 12Gb/s
Hard drive - hot-swap
1.8 TB
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Spindle Speed
10000 rpm
Advanced format 512e
75.7 mm x 118.7 mm x 15.6 mm
3-year warranty
Bundled with
HP SmartDrive carrier
Apollo 4200 Gen9; ProLiant BL420c Gen8, BL460c Gen10, BL460c Gen8, BL465c Gen8, BL660c Gen8, BL660c Gen9, DL160 Gen8, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen9, DL360e Gen8, DL380p Gen8, DL385p Gen8, DL388 Gen9, DL388p Gen8, DL560 Gen9, DL580, DL580 Gen8, DL580 Gen9, ML110 Gen9, ML150 Gen9, ML30 Gen9, ML350 Gen9, ML350e Gen8, WS460c Gen8, WS460c Gen9, XL250a Gen9; Synergy 480 Gen10, 660 Gen10
1.8 TB
2.5" SFF
SAS 12Gb/s
Bytes per Sector
512
75.7 mm
118.7 mm
15.6 mm
Bundled with
Performance
Drive Transfer Rate
1.2 GBps (external)
Seek Time
3.7 ms (average) / 7.3 ms (max)
Track-to-Track Seek Time
0.1 ms
Spindle Speed
10000 rpm
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5" SFF
Limited warranty - 3 years
10 °C
35 °C
HPE Apollo 4200 Gen9 for Google (2.5") , HPE ProLiant BL460c Gen10 (2.5"), BL460c Gen8 (2.5"), BL660c Gen8 Entry (2.5"), BL660c Gen9 (2.5"), DL180 Gen9 (2.5"), DL180 Gen9 Base (2.5"), DL180 Gen9 Entry (2.5"), DL180 Gen9 Storage (2.5"), DL20 Gen9 (2.5"), DL20 Gen9 Entry (2.5"), DL20 Gen9 Performance (2.5"), DL320e Gen8 Special Server (2.5"), DL320e Gen8 v2 Entry (2.5"), DL360 Gen9 (2.5"), DL360 Gen9 Base (2.5"), DL360 Gen9 CMS (2.5"), DL360 Gen9 Entry (2.5"), DL360 Gen9 High Performance (2.5"), DL360 Gen9 Performance (2.5"), DL388 Gen9 (2.5"), DL388 Gen9 Base (2.5"), DL388p Gen8 Base (2.5"), DL560 Gen9 (2.5"), DL560 Gen9 Base (2.5"), DL560 Gen9 Entry (2.5"), DL560 Gen9 Performance (2.5"), DL580 Gen8 Base (2.5"), DL580 Gen9 (2.5"), DL580 Gen9 Database (2.5"), DL580 Gen9 SAP HANA Scale-out Base Configuration (2.5"), DL580 Gen9 SAP HANA Scale-up Base Configuration (2.5"), DL580 Intel E7 8800v4 Scale-out SAP HANA Tailored Datacenter Integration Compute Block (2.5"), ML110 Gen9 (2.5"), ML110 Gen9 Base (2.5"), ML110 Gen9 Entry (2.5"), ML150 Gen9 (2.5"), ML150 Gen9 Base (2.5"), ML150 Gen9 Entry (2.5"), ML150 Gen9 Performance (2.5"), ML30 Gen9 (2.5"), ML30 Gen9 Base (2.5"), ML30 Gen9 Performance (2.5"), ML350 Gen9 (2.5"), ML350 Gen9 Base (2.5"), ML350 Gen9 Entry (2.5"), ML350 Gen9 Performance (2.5"), ML350e Gen8 v2 Entry (2.5"), WS460c Gen9 (2.5"), WS460c Gen9 Graphics (2.5"), WS460c Gen9 Graphics Expansion (2.5"), XL250a Gen9 Accelerator Tray (2.5") , HPE Synergy 480 Gen10 Base Compute Module (2.5"), 480 Gen10 Entry Compute Module (2.5"), 480 Gen10 Performance Compute Module (2.5"), 480 Gen10 Premium Backplane Compute Module (2.5"), 480 Gen10 Standard BackPlane Compute Module (2.5"), 480 Gen10 w/o Drives Compute Module (2.5"), 660 Gen10 Base Compute Module (2.5"), 660 Gen10 Compute Module (2.5"), 660 Gen10 Entry Compute Module (2.5"), 660 Gen10 Performance Compute Module (2.5"), 660 Gen10 Premium Compute Module (2.5")
