HPE HP Flexfabric 10GB 2P 534FLR-SFP+ AD
Quicklinx: C9D7WS00 Mfr#: 700751-B21
Wired / Wireless: Wired
Protocol: 10 Gigabit Ethernet
Compatibility: Unix, PC
Type: Network adapter
£105.45 ex VAT
£126.54 inc VAT
Are your enterprise data centers growing and requiring increased network performance? Increased workload demands are putting pressure on server I/O. The HP FlexFabric 10Gb 2-port 534FLR-SFP+ Adapter increases throughput for the HP ProLiant Gen8 DL and SL Server series by using the innovative HP FlexibleLOM form factor to offer dual-ports in an SFP+ adapter configuration that includes new storage I/O functionality, making it a full Converged Network Adapter. This is the solution of choice for workload-intensive computing environments.
  • Accelerates Server Performance
    The HPE FlexFabric 10Gb 2-port FLR-SFP+ 57810S Adapter boosts network performance with full line-rate 10GbE throughput across all ports.Provides increased server performance by delivering full hardware offload for storage traffic.
  • Robust Virtualization Capabilities
    The HPE FlexFabric 10Gb 2-port FLR-SFP+ 57810S Adapter delivers Single Root I/O Virtualization (SR-IOV) support to allow multiple operating systems to share a physical interconnect.Enhances network management and efficiency with support for VLAN tagging.
  • Streamlines Deployment and Management
    Makes BroadcomQLogic Ethernet solutions available across a wide range of HPE server platforms.Unifies NIC and storage management using HPE ProActive Insight architecture.
  • Network Partitioning to Reduce Network Sprawl and Take Full Advantage of Bandwidth
    Allowing administrators to configure a 10 Gb adapter as four separate partitions or physical functions. Eliminate multiple NICs, HBAs, cables consolidating multiple connections on to one network adapter.Ideal for customers in virtual server environments by allowing them to segment the high performance connection and provide the right amount of network bandwidth to the applications.
HPE FlexFabric 534FLR-SFP+ - network adapter - PCIe 2.0 x8 - 10 Gigabit SFP+ x 2
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.0 x8
PCI Specification Revision
PCIe 2.0
Ports
10 Gigabit SFP+ x 2
10GbE
Data Transfer Rate
10 Gbps
1 x Broadcom BCM57810S
RAM
256 MB
IEEE 802.3, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.1AX, IEEE 802.1Qbb, IEEE 802.1Qaz, IEEE 802.1Qau, IEEE 802.1Qbg, IEEE 802.2x
SuSE Linux Enterprise Server 11, SuSE Linux Enterprise Server 10, Microsoft Windows Server 2008, Microsoft Windows HPC Server 2008, Oracle Solaris 10, Red Hat Enterprise Linux 6.1, Red Hat Enterprise Linux 5.7, VMware ESXi 5.0 update 1, VMware ESX 4.1 update 2
Pricing Type
Factory integrated
1-year warranty
Network adapter
Plug-in card
PCI Express 2.0 x8
PCIe 2.0
Ports
10 Gigabit SFP+ x 2
Wired
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Status Indicators
Port status, link/activity
Auto-negotiation, Jumbo Frames support, PXE support, Large Send Offload (LSO), Receive Side Scaling (RSS), TCP Segmentation Offload (TSO)
Processor / Memory
RAM
256 MB
2 x 10Gb Ethernet - SFP+
FCC Class A certified, UL, VCCI Class A ITE, EN55024, EN55022 Class A, ICES-003 Class A, WEEE, RoHS, BSMI Class A, EN 61000-3-2:2006, EN 61000-3-3:2008
Pricing Type
Factory integrated
Limited warranty - 1 year
55 °C
5 - 95% (non-condensing)
C9D7 C2G 2m LC-LC 10Gb 50/125 OM3 Duplex Multimode PVC Fibre Optic Cable (LSZH) - Aqua In Stock £12.40
Compatibility: Unix
Compatibility: PC
Brand: HPE
