HPE HP Ethernet 1GB 2P 332T Adaptor
Quicklinx: 8PZQWS00 Mfr#: 615732-B21
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: PC
Type: Network adapter
£231.00 ex VAT
£277.20 inc VAT
The HP 332T is a dual-port, low-cost, low profile 1Gb adapter featuring the BCM5720 Broadcom single-chip solution in a PCIe 2.0 compliant form factor designed for select HP ProLiant Gen8 and Gen7 ML/DL/SL servers. It delivers full line-rate performance across all ports with low power consumption, providing Ethernet connectivity ideal for virtualization, security, server consolidation, and network segmentation. Supported advanced features include Large Send and Receive offload capability, TCP checksum and segmentation, VLAN tagging, MSI-X, jumbo frames, IEEE 1588 (Precision Time Protocol – PTP), and virtualization features such as VMware NetQueue and Microsoft Virtual Machine Queue (VMQ). Support for HP Sea of Sensors 3D Technology enhances server performance while reducing energy use and expense.
  • Single-chip, Dual-port, 1 Gb Ethernet Adapter Designed for Performance and Energy Savings
    An aggregate, full duplex transfer rate of 4 Gb/s per adapter improves response times and alleviates bottlenecks.Comprehensive stateless offloads optimize host efficiency and virtual machine density by offloading network processes from the host CPU.Virtualization support for VMware NetQueue and Microsoft VMQ helps meet the performance demands of consolidated virtual workloads.Support for MSI/MSI-X provides performance benefits for multi-core servers by load balancing interrupts between CPUs/cores.Support for Energy Efficient Ethernet (EEE) reduces operating expenses.
HPE 332T - network adapter - PCIe 2.0 - Gigabit Ethernet x 2
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x1
PCI Specification Revision
PCIe 2.0
Ports
11.2 cm x 6 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
1 x Broadcom BCM5720
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1as, IEEE 802.3az
Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10, Medium Solution with HPE ProLiant DL360 Gen10, Small Solution with HPE ProLiant DL360 Gen10; ProLiant DL180 Gen10, DL360 Gen10, DL380 Gen10, DL388p Gen8, DL560 Gen10, MicroServer Gen10, ML350 Gen10, XL170r Gen10, XL190r Gen10
Network adapter
PCI Express 2.0 x1
PCIe 2.0
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Status Indicators
Link/activity
Jumbo Frames support, PXE support, LSO
Processor / Memory
2 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI Express 2.0 x1
Low-profile bracket, full-height bracket
VCCI Class B ITE, EN 61000-3-2, EN55022, EN 61000-3-3, FCC Part 15 B, WEEE, RoHS
11.2 cm
6 cm
55 °C
10 - 90% (non-condensing)
HPE Apollo 4200 Gen10, 4200 Gen9 for Google , HPE Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10, Medium Solution with HPE ProLiant DL360 Gen10, Small Solution with HPE ProLiant DL360 Gen10 , HPE ProLiant DL180 Gen10, DL180 Gen10 Entry, DL180 Gen10 SMB, DL20 Gen10, DL20 Gen10 Entry, DL20 Gen10 Performance, DL20 Gen10 solution, DL20 Gen9 Solution, DL325 Gen10 Base, DL325 Gen10 Solution, DL360 Gen10 All Flash Server for Weka, DL360 Gen10 Compute Server for Cohesity DataPlatform, DL360 Gen10 Low, DL360 Gen10 Network Choice, DL360 Gen10 Performance for Cohesity DataPlatform, DL360 Gen10 SMB, DL360 Gen10 SMB Network Choice, DL360 Gen10 Solution, DL380 Gen10 All Flash Server for Datera, DL380 Gen10 Entry SMB, DL380 Gen10 for Cohesity DataPlatform, DL380 Gen10 for SAP HANA Compute Block, DL380 Gen10 Hybrid Server for Datera, DL380 Gen10 Network Choice, DL380 Gen10 Network Choice for CTERA, DL380 Gen10 NVMe All Flash Server for Datera, DL380 Gen10 Server for CTERA, DL380 Gen10 SMB, DL380 Gen10 SMB Networking Choice, DL380 Gen10 Solution, DL388 Gen10 Network Choice, DL388p Gen8 Base, DL560 Gen10 for SAP HANA Compute Block, DL580 Gen10, DL580 Gen10 Base, DL580 Gen10 Entry, DL580 Gen10 Performance, MicroServer Gen10, MicroServer Gen10 Solution, MicroServer Gen10 Stockage Collaboration, ML110 Gen10, ML110 Gen10 Entry, ML110 Gen10 Solution, ML30 Gen10, ML30 Gen10 Entry, ML30 Gen10 Performance, ML30 Gen10 Solution, ML30 Gen9 Entry, ML30 Gen9 Solution, ML350 Gen10 Base, ML350 Gen10 Entry, ML350 Gen10 High Performance, ML350 Gen10 Performance, ML350 Gen10 SMB, ML350 Gen10 Solution, ML350 Gen10 Special Server, ML350 Gen10 Sub-Entry, XL170r Gen10, XL170r Gen10 24TB Server for Cohesity DataPlatform, XL170r Gen10 36TB Add-on Server for Cohesity DataPlatform, XL170r Gen10 Server for BlueData EPIC, XL190r Gen10, XL190r Gen10 for HPE Ezmeral Container Platform, XL450 Gen10 , HPE StoreEasy 1660, 1660 Expanded Storage
8PZQ C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
8PZQ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.73
8PZQ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: PC
Brand: HPE
