Are you looking to reduce network congestion and improve cable management at the servers in your HPE ProLiant Gen8 and Gen 9 environment? The HPE Ethernet 10Gb 2-port 530T Adapter is a dual-port 10GBASE-T adapter, featuring the QLogic 57810S 10 Gb Ethernet solution from QLogic, in a PCIe 2.0 compliant form factor designed for HPE ProLiant Gen8 and Gen 9 rack and tower servers. HPE 530T Adapter delivers full line-rate performance across all ports with low power consumption, utilizing CAT 6A UTP cabling with distances up to 100 meters. Providing high performance Ethernet connectivity, it is ideal for virtual server and cloud computing environments. It supports enterprise class features (VLAN tagging, adaptive interrupt coalescing, MSI-X, NIC teaming (bonding), Receive Side Scaling (RSS), jumbo frames, PXE boot) and virtualization features (VMware NetQueue and Microsoft VMQ). The adapter's support for HPE Sea of Sensors 3D Technology enhances server performance by reducing energy consumption and expense.
Dual-port 10GBASE-T Ethernet Low Profile Adapter Designed for Increased Network Performance
Total aggregate, full-duplex throughput of 40 Gb/s provides the network performance needed to improve response times and alleviate bottlenecks that impact performance of the most demanding workloads. Compatible with 1GbE networks utilizing CAT 6A UTP cabling to support distances up to 100 meters.Comprehensive stateless offloads that optimize host efficiency and virtual machine density by leaving host CPU availability for other duties.Virtualization support for VMware NetQueue and Microsoft VMQ helps meet the performance demands of consolidated virtual workloads.Support for MSI/MSI-X provides performance benefits for multi-core servers by load balancing interrupts between CPUs/cores.Stateful hardware offload for TCP/IP: TCP Offload Engine (TOE). Optimizes CPU utilization. Backward compatible with existing 1GbE networks utilizing low-cost CAT 6A UTP cabling to support distances up to 100 meters. -
Network Partitioning to Reduce Network Sprawl and Take Full Advantage of Bandwidth
Allows administrators to configure a 10 Gb adapter as four separate partitions or physical functions. Eliminate multiple NICs, HBAs, and cables to consolidate multiple connections onto one network adapter.Ideal for customers in virtual server environments because it allows them to segment the high performance connections and provide the right amount of network bandwidth to applications.
- HPE 530T - network adapter - PCIe 2.0 x8 - 10Gb Ethernet
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express 2.0 x8
- Ports
- 10Gb Ethernet
- Cabling Type
- Ethernet 1000Base-T, Ethernet 10GBase-T
- Data Link Protocol
- 1GbE, 10GbE
- Processor
- Broadcom BCM57810S
- RAM
- 256 MB
- IEEE 802.3, IEEE 802.1Q, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1AX, IEEE 802.1Qbb, IEEE 802.1Qaz, IEEE 802.1Qau, IEEE 802.1Qbg, IEEE 802.2x
- System Requirements
- SunSoft Solaris 10, Microsoft Windows HPC Server 2008 SP2, Microsoft Windows Small Business Server 2011 Essentials, Microsoft Windows MultiPoint Server 2011, Microsoft Windows Small Business Server 2011, Microsoft Windows Server 2008 (32/64-bits) SP2, Red Hat Enterprise Linux 6.1, Red Hat Enterprise Linux 6.2, Red Hat Enterprise Linux 5.7, SuSE Linux Enterprise Server 10 SP4, Citrix XenServer 6.0, SuSE Linux Enterprise Server 11 SP2, Microsoft Windows Server 2012, Red Hat Enterprise Linux 5.8, Microsoft Windows Server 2008 R2 SP1 (32/64 bits), Microsoft Windows HPC Server 2008 R2 SP1, Red Hat Enterprise Linux 5.9, Red Hat Enterprise Linux 6.3, SunSoft Solaris 11, Citrix XenServer 6.1
- Designed For
- Apollo 4200 Gen10; Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10, Medium Solution with HPE ProLiant DL360 Gen10, Small Solution with HPE ProLiant DL360 Gen10; ProLiant DL180 Gen10, DL360 Gen10, DL380 Gen10, DL388p Gen8, DL560 Gen10, XL170r Gen10, XL190r Gen10; SimpliVity 380 Gen10
- Network adapter
- Form Factor
- Plug-in card
- Ports
- 10Gb Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- Gigabit Ethernet, 10 Gigabit Ethernet
- TCP/IP offloading, Jumbo Frames support, teaming support, PXE support, RSS, tagged VLAN, MSI-X
Processor / Memory
- Processor
- RAM
- 256 MB
- 1 x 10GBase-T - RJ-45
- Compatible Slots
- 1 x PCI Express 2.0 x8
- UL, BSMI, BSMI CNS 13438 Class A, EN55024, EN55022 Class A, ICES-003 Class A, WEEE, FCC Part 15 A, EN 61000-3-2:2006, EN 61000-3-3:2008
- OS Required
- 0 °C
- 55 °C
- 5 - 95% (non-condensing)
- Designed For
- HPE Apollo 4200 Gen10, 4200 Gen10 for HPE Ezmeral Container Platform, 4200 Gen10 for HPE Ezmeral Tracking, 4200 Gen9 for Google , HPE Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10, Medium Solution with HPE ProLiant DL360 Gen10, Small Solution with HPE ProLiant DL360 Gen10 , HPE ProLiant DL120 Gen10, DL180 Gen10, DL180 Gen10 Entry, DL180 Gen10 SMB, DL20 Gen10, DL20 Gen10 Entry, DL20 Gen10 Performance, DL20 Gen10 solution, DL20 Gen9 Solution, DL325 Gen10 Base, DL325 Gen10 Solution, DL360 Gen10 All Flash Server for Weka, DL360 Gen10 Compute Server for Cohesity DataPlatform, DL360 Gen10 Low, DL360 Gen10 Network Choice, DL360 Gen10 Performance for Cohesity DataPlatform, DL360 Gen10 SMB, DL360 Gen10 SMB Network Choice, DL360 Gen10 Solution, DL380 Gen10 All Flash Server for Datera, DL380 Gen10 Entry SMB, DL380 Gen10 for Cohesity DataPlatform, DL380 Gen10 for SAP HANA Compute Block, DL380 Gen10 Hybrid Server for Datera, DL380 Gen10 Network Choice, DL380 Gen10 Network Choice for CTERA, DL380 Gen10 NVMe All Flash Server for Datera, DL380 Gen10 Server for CTERA, DL380 Gen10 SMB, DL380 Gen10 SMB Networking Choice, DL380 Gen10 Solution, DL388 Gen10 Network Choice, DL388p Gen8 Base, DL560 Gen10 for SAP HANA Compute Block, DL580 Gen10 Base, DL580 Gen10 Entry, DL580 Gen10 Performance, ML110 Gen10 Solution, ML30 Gen10, ML30 Gen10 Entry, ML30 Gen10 Performance, ML30 Gen10 Solution, ML30 Gen9 Entry, ML30 Gen9 Solution, ML350 Gen10 High Performance, ML350 Gen10 SMB, ML350 Gen10 Solution, ML350 Gen10 Special Server, XL170r Gen10 24TB Server for Cohesity DataPlatform, XL170r Gen10 36TB Add-on Server for Cohesity DataPlatform, XL170r Gen10 Server for BlueData EPIC, XL190r Gen10 for HPE Ezmeral Container Platform, XL450 Gen10 , HPE SimpliVity 325 Gen10 Node, 380 Gen10 G Node, 380 Gen10 H Node, 380 Gen10 Network Choice G Node, 380 Gen10 Network Choice H Node, 380 Gen10 Node , HPE StoreEasy 1660 Expanded Storage
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £4.30 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.80 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.24 |
