HPE HP E5406-44G-PoE+/4G v2 zl Switch w Prm SW
Quicklinx: 7ZVJWS00 Mfr#: J9539A
Type: Gigabit Ethernet
Ports: 44
Managed: Yes
POE: PoE
£4,366.16 ex VAT
£5,239.39 inc VAT
The HP 5400 zl Switch Series is a HP Networking ASIC based modular switch designed for enterprise-edge, SMB, and branch office core deployments. This Layer 3 switch has 760 Gbps backplane and license free software with an advanced Layer 2 and 3 feature set including IPv6, IPv4 BGP, policy based routing, OSPF and robust QoS. Virtualization with HP AllianceOne solutions and flexible connectivity including 1 and 10 Gigabit Ethernet and PoE+, the 5400 zl Switch Series is Software-defined Network (SDN) ready with support for OpenFlow.
  • Flexible, Scalable and SDN Ready for the Campus Network
    The HP 5400 zl Switch Series provides flexibility, scalability and ease of use for enterprise edge, SMB, and branch office core deployments. This modular switch has license free software with an advanced Layer 2 and 3 feature set; IPv4 BGP, policy based routing, IPv4/IPv6 OSPF, and robust QoS.Purpose-built HP Networking ASIC delivers wire-speed classification and policy enforcement. This hardware-based control of access and traffic allows protection, detection and response to network threats with no network performance degradation.Flexible connectivity options with 6 or 12 slot chassis with support for 10/100, Gigabit Ethernet and 10 Gigabit Ethernet (10GBASE-T and SFP+), and PoE+.Robust virtualization with versatile HP AllianceOne service modules.Software-defined Network (SDN) ready with OpenFlow support for future proofing your network.
  • Security and Quality of Service
    The HP 5400 zl Switch Series includes security and quality of services features so your network can more securely deliver the performance your users require.Flexible authentication options include Local MAC Authentication, 802.1X, MAC and Web Authentication, for enhanced security and policy-driven application authentication.Advanced distributed denial of service (DDOS) protection, such as DHCP Snooping, IP Source Guard, and ARP Protection, and flexible traffic controls, such as policy-based routing, QoS, and ACLs, to manage end-to-end application priorities.Powerful multilevel-access security controls, such as varying security management login, RADIUS/TACACS+, and SSH to enhance security and control change management access.Defend the edge of your IPv6 network with DHCPv6 Protection and Dynamic IPv6 Lockdown.
  • Single View of the Network
    The HP 5400 zl Switch Series can be seamlessly managed with HP Intelligent Management Center (IMC) Software Platform to provide end-to-end network transparency with consistent network experience through comprehensive configuration, compliance and policy management.RMON, XRMON and sFlow provide advanced monitoring and reporting capabilities for statistics, history, alarms and events.
HPE Aruba 5406-44G-PoE+-4G-SFP v2 zl - switch - 44 ports - Managed - rack-mountable - with HP 5400 zl Switch Premium License
Switch - 44 ports - L4 - Managed - with HP 5400 zl Switch Premium License
Enclosure Type
Rack-mountable 4U
Subtype
Gigabit Ethernet
Ports
44 x 10/100/1000 (PoE) + 4 x SFP
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity: 379.2 Gbps
MAC Address Table Size
64K entries
Routing Protocol
RIP-1, RIP-2, OSPFv2, static IP routing, IGMPv3, OSPFv3, static IPv6 routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP
Flow control, routing, power over Ethernet (PoE), BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), DiffServ support, manageable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, PoE+
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 801.1p, IEEE 802.1v
44.5 cm x 45.1 cm x 17.5 cm
20.7 kg
Enclosure Type
Rack-mountable 4U
Subtype
Gigabit Ethernet
Ports
PoE
Performance
64K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
1 x Freescale PowerPC 8540: 666 MHz
RAM
256 MB DDR SDRAM
Flash Memory
4 MB
44 x 1000Base-T RJ-45 PoE , 1 x RS-232C management , 4 x SFP (mini-GBIC)
Expansion Slots
6 (total) / 4 (free) x Expansion Slot , 1 (total) / 1 (free) x CompactFlash Card
Installed Modules Qty (Max)
2 (installed) / 6 (max)
Rack Mounting Kit
Included
FCC Class A certified, CISPR 22 Class A, CISPR 24, EN 60950, EN 61000-3-2, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, IEC 60950, EN 61000-3-3, EN55024, UL 60950, CSA 22.2 No. 60950
44.5 cm
45.1 cm
17.5 cm
20.7 kg
55 °C
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
7ZVJ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
7ZVJ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
7ZVJ HPE Premier Flex Network cable 5m Fibre Optic In Stock £35.58
Ports: 44
Managed: Yes
POE: PoE
Brand: HPE
Price Range Ex VAT: £1500+
