HPE DLT IV 40-80GB Pre-Labelled Data Cartridge (20 pack)
Quicklinx: 86F2WS00 Mfr#: C5141FL
HP SDLT storage media is ideally suited for data center and departmental backups where compatibility with existing DLT libraries, performance, and cost per megabyte are critical. HP DLT is ideal for mid-range to enterprise requiring reliable, high-capacity back up. DLT is the answer to the high-capacity storage and archiving needs of mid-range systems, network servers and high-end workstations.
HPE DLT Custom Labeled Data Cartridge - DLT IV x 20 - 40 GB - storage media
Storage media - DLT
Tape Cartridge
DLTtape IV
Media Included Qty
20
Native Capacity
40 GB
Compressed Capacity
80 GB
Tape Record Formats
DLT8000
Cartridge Labeling
Bar code labeled
DLT 3570, 4000, 7000, 8000; Smart Storage DLT 4000, DLT 7000, DLT 8000; StorageWorks ESL9236; SureStore E Tape Library 2/20, E Tape Library 4/40, E Tape Library 6/60; SureStore Tape Autoloader 1/9; SureStore Tape Library 1/20, 10/100, 10/588, 2/20, 2/40, 2/60, 20/700, 4/100, 4/40, 4/60, 6/140, 6/60
DLT
Tape Cartridge
DLTtape IV
Media Included Qty
20
Cartridge Labeling
Bar code labeled
Media
Native Capacity
40 GB
Compressed Capacity
80 GB
Tape Record Formats
DLT8000
Compaq StorageWorks Enterprise ESL9326DX , HP DLT 2040 , HP StorageWorks DLT VS 40/80 , HPE DLT 3570, 4000, 7000, 8000 , HPE Smart Storage DLT 4000, DLT 7000, DLT 8000 , HPE StorageWorks DLT 40/80, DLT 80, DLT 80 Tape Array III, DLT VS 80, ESL9198DLX, ESL9236D, MSL5026DLX , HPE StorageWorks 1/8 Tape Autoloader DLT VS80 , HPE StorageWorks SSL1016 Tape Autoloader DLT1 , HPE SureStore E Tape Library 2/20, E Tape Library 4/40, E Tape Library 6/60 , HPE SureStore DLT 1, 1e, 4000, 40e, 40i, 40r, 70e, 70i, 70r, 8000, 80E, 80I, 80I Select Express, 80k, 80m, 80R, Autoloader 418, Autoloader 718, Autoloader 818, E Tape Library 10/180, E Tape Library 2/20, E Tape Library 4/40, E Tape Library 6/140, E Tape Library 6/60, Library 1/20, Library 2/15, Library 2/20, Library 2/28, Library 2/40, Library 2/60, Library 3/30, Library 4/40, Library 4/60, Library 4115e, Library 4115r, Library 4115we, Library 4115wr, Library 4215e, Library 4215r, Library 4215we, Library 4215wr, Library 4228w, Library 4448w, Library 6/60, Library 7115we, Library 7115wr, Library 7215we, Library 7215wr, Library 7228w, Library 7248w, Library 7448w, Tape Autoloader 1/9, vs80, vs80e, vs80i, vs80m , HPE SureStore Tape Autoloader 1/9 , HPE SureStore Tape Library 1/20, 10/100, 10/588, 2/20, 2/40, 2/60, 20/700, 4/100, 4/40, 4/60, 6/140, 6/60
