HPE HP DL320 G6, Dual Processor Capable, 1 x Xeon E5603 (1.6Ghz)
Quicklinx: 7GZ4WS00 Mfr#: 470065-491
  • Xeon
  • Red Hat Enterprise Linux
The HP ProLiant DL320 G6 Server is an enterprise rack-optimized server at an entry level price. The highly manageable single processor, 1U server is ideal for single-application IT infrastructure, web and edge-of-network applications. The remote console and virtual KVM offered by the embedded ProLiant Onboard Administrator powered by Integrated Lights-Out 2, coupled with the management features of SIM and deployment capabilities of SmartStart and other ProLiant Essentials software, give the DL320 G6 enterprise-class management features. Support for one or two low-cost Serial ATA drives on an integrated RAID0/1 controller, with an optional upgrade to highly reliable hot plug SAS hard drives, gives the DL320 G6 flexibility to meet the needs of your datacenter. Plus, you get the cost-effective solution of a single-processor platform with options from the new Intel Xeon Processor 3000 sequence with turbo mode.
  • Low Cost, Enterprise Class Rack-Dense Platform
    1U, 24-inch (60.96 cm) deep chassis.Spring-loaded Universal sliding rails included.Dedicated application server support for: Up to 2.53 Intel Xeon 2 core (40, 60, 80, 95 and 130 Watts) processors with Turbo Mode Up to 1333FSB DDR3 1333MHz DIMMS.Standard support for four 3.5-inch Serial ATA (SATA) hard drives (8 SFF optional).Support for the latest Microsoft Windows, Novell and Red Hat Linux operating systems.
  • Enterprise Class Monitoring and Management
    ProLiant Onboard Administrator powered by Integrated Lights-Out 2 server management, which provides virtual presence and control of your servers over the network, is embedded.Fully integrated hardware-based management without needing additional plug-in adapters.SmartStart deployment tool to radically simplifies server deployment.HP Systems Insight Manager (SIM), the world's leading server management tool.Tool-free entry and easy access to critical system components makes it simple to maintain your server.
  • Flexible Storage Options
    Support for up to four 3.5-inch Serial ATA (SATA) hard drives, plus an integrated SATA controller that supports RAID 0 or RAID 1. SATA hard drive options from low-cost 80GB hard drives to massive 1TB hard drives.Optional support for hot plug SATA or Serial Attached SCSI (SAS) hard drives when using an optional HBA (Host Bus Adapter) or RAID card, support for hot plug hard drives.
HPE ProLiant DL320 G6 - rack-mountable - Xeon E5603 1.6 GHz - 2 GB - HDD 500 GB
Server - rack-mountable - administrator password, power-on password, serial port I/O control, USB port control
Height (Rack Units)
1U
Server Scalability
1-way
1 x Intel Xeon E5603 / 1.6 GHz (Quad-Core)
Processor Socket
LGA1366 Socket
Processor Main Features
Intel Smart Cache
Cache Memory
4 MB L3 Cache
Cache Per Processor
4 MB
RAM
2 GB (installed) / 24 GB (max) - DDR3 SDRAM - ECC - PC3-10600
Storage Controller
SATA (SATA 3Gb/s) (Smart Array B110i)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
HDD 500 GB (hot-swap) - SATA 3Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
ATI ES1000
Video Memory
64 MB
GigE
Windows Server Certified
This server is tested, tuned and certified for Windows Server 2008 R2 with OEM-branded hardware. Purchase a Reseller Option Kit to have your server solution pre-loaded.
44.8 cm x 68.2 cm x 4.3 cm
11.6 kg
Limited warranty - parts and labour - 3 years - on-site
Server
Recommended Use
Small business, corporate business
Product Form Factor
Rack-mountable - 1U
Server Scalability
1-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Intel Xeon E5603
Clock Speed
1.6 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Intel Smart Cache
CPU Socket
LGA1366 Socket
Chipset Type
Intel 5500
Cache Memory
Installed Size
L3 Cache - 4 MB
Cache Per Processor
4 MB
RAM
Installed Size
2 GB / 24 GB (max)
DDR3 SDRAM - ECC
Effective Memory Speed
1066 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
9 (Total) / 8 (empty)
Unbuffered
Configuration Features
1 x 2 GB
RAM Supported
144 GB registered - ECC , 24 GB unbuffered - ECC
Hard Drive
HDD - hot-swap
1 x 500 GB
Interface Type
SATA 3Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Storage Controller Name
Smart Array B110i
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
ATI ES1000
Video Memory
64 MB
Video Interfaces
VGA
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
HP NC326i
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Wake on LAN (WoL), ACPI support, PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Bays
4 (total) / 3 (free) x hot-swap 3.5" LFF , 1 (total) / 1 (free) x external 5.25" Slim Line
Slots
1 (total) / 1 (free) x PCIe x4 - half-length, low-profile (x1 mode) , 1 (total) / 1 (free) x PCIe x16 - full-length (x16 mode) , 1 (total) / 1 (free) x SD card
1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial , 1 x VGA , 6 x USB 2.0 (2 in front) , 2 x LAN (Gigabit Ethernet) (2 in front) , 1 x HPE iLO
Administrator password, power-on password, serial port I/O control, USB port control
ACPI 2.0, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, BSMI CNS 13438
Power supply
Power Provided
500 Watt
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Enterprise Linux
44.8 cm
68.2 cm
4.3 cm
11.6 kg
10 °C
35 °C
10 - 90% (non-condensing)
Sound Emission
51.4 dBA
