HPE HP BLc3000 4 AC-6 Fan Full ICE
Quicklinx: 7CSYWS00 Mfr#: 508664-B21
The HP BladeSystem c3000 Platinum Enclosure brings new capabilities to HP BladeSystem. The c3000 targets three separate market segments: 1) remote sites needing between 2 and 8 server blades; 2) mid-sized companies with between 3 and 100 servers; and 3) enterprise accounts with special datacenter requirements, such as DC power, or very limited rack power and cooling capacity. Similar to the c7000, the Intelligent Management through the Onboard Administrator gives you complete control of your bladed infrastructure. A multi-terabit backplane ensures that the c3000 Enclosure can support today's Gigabit networks with an easy migration to tomorrow's 10 Gigabit solutions.
  • Simple to Manage, Easy to Control
    The HP BladeSystem c3000 Platinum Enclosure goes beyond just servers. It integrates server, storage (NAS or iSCSI), networking, power/cooling, and management into a single solution that can be deployed anywhere.With demanding workloads and rising complexities, the Intelligent Infrastructure technologies such as Platinum Power Supplies, Intelligent Power Module and PDU have enhanced the foundation for converged infrastructure.With Onboard Administrator, iLO remote management, and HP Insight Control you can manage your servers and take complete control regardless of the state of the server Operating System.Easy setup and management using tools you're used to, such as a local DVD drive for SmartStart software deployment, and a local KVM interface for local rack-based KVM integration.
  • Change Ready IT That Can Grow and Flex with your needs
    Pre-wired and pre-configured, the c3000 Platinum Enclosure can easily implement a new server blade, simply as just plugging it in.Going beyond just virtual servers, the c3000 Platinum Enclosure allows you to virtualize your network, storage, and power infrastructure so you can reduce costs while protecting your business assets against disasters.HP Insight Control is essential infrastructure management that unlocks the management capabilities built into HP ProLiant servers. Insight Control delivers powerful capabilities that enable one to proactively manage ProLiant server health either physical or virtual.Virtual Connect architecture delivers wire once, and then add, replace, or recover blades on the fly without impacting networks and storage or creating extra steps.
  • Reduce Up-front Capital and Ongoing Management Costs
    Costs less than equivalent rack-mounted servers (at 3 servers or more).Use up to 30% less power and 40% less space when compared to equivalent 1U rack mount servers.Deploy anywhere with a choice of UPS's, PDU's and wall outlet power, as well as a choice of low-line or high-line AC Power supplies.Optimize power efficiency with HP Dynamic Power Saver to place unused power supplies in standby.Provide flexibility in deploying into non-datacenter environments, such as high ambient temperatures, low-line, or high-line power outlets.
HPE BLc3000 Enclosure - rack-mountable - 6U
System cabinet
Rack-mountable - 6U
Installed Fans Qty
6
Power supply - hot-plug
48.5 cm x 83.5 cm x 26.5 cm
59 kg
3-year warranty
ProLiant BL280c G6, BL2x220c G5, BL460c G5, BL460c G6, BL465c G6, BL490c G6, BL495c G5, BL495c G6, BL685c G5, BL685c G6, SB460, WS460c G6; StorageWorks SB1760; StorageWorks All-in-One Storage System SB600c 1.16; StorageWorks Network Storage Blade X1800; StorageWorks Network Storage Gateway X3800
Rack-mountable - 6U
Fans
Rear: 6 - (6 installed)
Expansion Slots
8 x Expansion Slot
Installed Qty
4
Max Supported Qty
6
48.5 cm
83.5 cm
26.5 cm
59 kg
Limited warranty - parts and labour - 3 years - on-site
10 °C
35 °C
10 - 90%
HPE Integrity BL860c, BL870c , HPE ProLiant BL260c G5, BL280c G6, BL2x220c G5, BL2x220c G5 Server A, BL2x220c G5 Server B, BL460c, BL460c G5, BL460c G6, BL465c, BL465c G5, BL465c G6, BL480c, BL490c G6, BL495c G5, BL495c G6, BL680c G5, BL685c, BL685c G5, BL685c G6, SB460c SAN Gateway Storage Server, WS460c G6 Workstation, xw460c Blade Workstation , HPE StorageWorks SB1760c Tape Blade, SB40c storage blade , HPE StorageWorks All-in-One Storage System SB600c 1.16TB Storage Blade , HPE StorageWorks Network Storage Blade X1800sb , HPE StorageWorks Network Storage Gateway X3800sb , HPE StorageWorks Ultrium 448c Tape Blade, SB920c
