HPE HP AMD FirePro W5100 4GB Graphics
Quicklinx: BFD1WS00 Mfr#: J3G92AT
Power through your CAD and Media & Entertainment applications with the latest professional GPU solution found in the AMD FirePro 5100 graphics card loaded with 4 GB GDDR5 memory.
  • Reliable ISV compatibility
    Get support for your professional software with a graphics card that's optimized and certified for more than 100 different leading workstation ISV applications.
  • Efficient performance
    Balance your GPU compute and 3D workloads with the AMD Graphics Core Next (GCN) architecture.
  • Outstanding multi-display support
    Get superb visual quality from four DisplayPort 1.2a outputs and drive up to four displays with resolutions up to 4k from a single card. Manage your multi-display screen real estate as one cohesive display with AMD Eyefinity.
AMD FirePro W5100 - graphics card - FirePro W5100 - 4 GB - Smart Buy
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD FirePro W5100
4 GB GDDR5
Core Clock
930 MHz
Stream Processors
768
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI (Single-Link): 1920 x 1200 / DVI (Dual-Link): 2560 x 1600 / DisplayPort: 4096 x 2160 / VGA: 1920 x 1200
Max Monitors Supported
6
Interfaces Details
4 x DisplayPort , 4 x DVI-D - with adapter , 4 x DVI-D (dual link) - with adapter , 4 x VGA - with adapter
API Supported
DirectX 11.2, OpenGL 4.4, DirectX 12
Manufacturer Selling Program
HP Smart Buy
Workstation Z440, Z640, Z840
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD FirePro W5100
Core Clock
930 MHz
Stream Processors
768
Max Resolution
4096 x 2160 at 60 Hz
6
Interfaces Details
API Supported
AMD Eyefinity Technology, AMD PowerTune technology, AMD GeometryBoost Technology, Shader Model 5.0, AMD ZeroCore Power technology, AMD Mantle technology, FreeSync Technology
Size
4 GB
GDDR5 SDRAM
Bus Width
128-bit
Bandwidth
96 GBps
Linux, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
75 Watt
HP Smart Buy
HP Workstation Z440, Z640, Z840
BFD1 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.57
BFD1 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £14.94
