HPE HP 6Gb 2-ports Ext PCIe Storage Controlle
Quicklinx: 80JNWS00 Mfr#: 614988-B21
HP Modular Smart Array SC08e 2-ports Ext PCIe x8 SAS Host Bus Adapter
HPE SC08e - storage controller - SAS - PCIe
Storage controller - plug-in module
Bus Type
PCIe
SAS
Data Transfer Rate
6 Gbit/s
Modular Smart Array 2040, 2040 10Gb, P2000 G3; ProLiant DL160 G6, DL160se G6, DL165 G6, DL165 G7, DL180 G6, DL320 G6, DL360 G6, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL385 G6, DL385 G7, DL580 G7, DL585 G6, DL585 G7, DL785 G6, DL980 G7, ML330 G6, ML350 G6, ML370 G6
Host Bus
PCIe
Storage Controller
SAS
Data Transfer Rate
6 Gbit/s
2 x SAS (external)
Compatible Slots
1 x PCI Express
HPE Modular Smart Array 2040 10Gb iSCSI Dual Controller SFF Bundle, 2040 Dual Controller SFF Bundle, 2040 FC Dual Controller SFF Bundle, 2040 SAN Dual Controller SFF Bundle, 2040 SAS Dual Controller LFF Storage, 2040 SAS Dual Controller SFF Bundle, P2000 G3 10GbE iSCSI Dual Controller SFF Array System , HPE ProLiant DL160 G6, DL160 G6 Special Server, DL160se G6, DL165 G6, DL165 G7, DL165 G7 Special Server, DL180 G6, DL180 G6 Special Server, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Efficiency, DL380 G7 Entry, DL380 G7 Performance, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G6, DL585 G6 Base, DL585 G6 Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G6, DL785 G6 Base, DL785 G6 Performance, DL980 G7, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML330 G6 Performance, ML330 G6 Special Server, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML350 G6 Special Server, ML370 G6, ML370 G6 Base, ML370 G6 Entry
