HPE 4GB(1x4GB) DDR31866 ECC RegRAM
Quicklinx: 9RG8WS00 Mfr#: E2Q92AT
Boost the capabilities of your HP Workstation and newest multi-core processors. Choose ultra-fast 2 GB, 4 GB, 8 GB, or 16 GB 1866 MHz DDR3 memory from HP, a cost-effective way to improve system performance and application responsiveness.
HP - DDR3 - module - 4 GB - DIMM 240-pin - 1866 MHz / PC3-14900 - registered
Memory module
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1866 MHz (PC3-14900)
Registered
HP E2Q92AT
Pricing Type
Promo
Workstation Z620, Z820
4 GB
Upgrade Type
System specific
HP E2Q92AT
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Speed
ECC
Registered
Compatible Slots
1 x memory - DIMM 240-pin
Pricing Type
Promo
HP Workstation Z620, Z820
