Your basket is empty
HPE HP 4GB (1x4GB) DDR3-1866 MHz ECC Registered RAM
Quicklinx: BFBZWS00 Mfr#: E2Q92AA
Type: DDR3 SDRAM
Capacity: 4GB
Connection: DIMM 240-pin
Speed: 1866MHz
Registered/Buffered: Registered
£88.93 ex VAT
£106.71 inc VAT
Boost the capabilities of your HP Workstation and newest multi-core processors. Choose ultra-fast 2 GB, 4 GB, 8 GB, or 16 GB 1866 MHz DDR3 memory from HP, a cost-effective way to improve system performance and application responsiveness.
HPE - DDR3 - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1866 MHz ( PC3-14900 )
Registered
HP E2Q92AA
Pricing Type
CTO
Workstation Z620, Z820
4 GB
Upgrade Type
System specific
HP E2Q92AA
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
ECC
Registered
Chips Organization
512 x 4
Compatible Slots
1 x memory - DIMM 240-pin
Pricing Type
CTO
HP Workstation Z620, Z820
Type: DDR3 SDRAM
Capacity: 4GB
Speed: 1866MHz
Brand: HPE
Price Range Ex VAT: 50 - 100
