HPE HP 45W USB-C POWER ADAPTER
Quicklinx: C99JWS00 Mfr#: V5Y26AA#ABU
£48.75 ex VAT
£58.50 inc VAT
Power and charge your notebook or tablet from its USB-C port with the HP 45W USB-C AC Adapter.
  • Simple to use
    Connect one end of the adapter to the USB-C port on your device, and plug the AC head into any available wall outlet.
  • World-class support
    Rest easy with a One-year limited warranty.
HP - power adapter - 45 Watt
Power adapter - external
English / United Kingdom
Input Voltage
AC 115/230 V
Output Voltage
5 / 12 / 15 V
Power Capacity
45 Watt
Output connectors
1 x 24 pin USB-C
6.6 cm x 2.85 cm x 6.6 cm
1-year warranty
Chromebook 13 G1; Elite x2 1012 G1, 1012 G2; EliteBook Folio G1; MX12 Retail Solution; Pro x2 612 G2; ProBook 440 G4 Notebook, 440 G6 Notebook, 450 G6 Notebook, 455 G4 Notebook; Spectre Pro 13 G1; x2 210 G2
Input Voltage
AC 115/230 V
Frequency Required
47 - 63 Hz
1 x 24 pin USB-C
Output Voltage
5 / 12 / 15 V
Max Electric Current
5 A
Power Capacity
45 Watt
FCC Class B certified, NORDIC, IEC 60950, UL 60950, EN55022 Class B, CCC, EMC, NOM-1-NYCE
Limited warranty - 1 year
35 °C
0 - 95% (non-condensing)
6.6 cm
2.85 cm
6.6 cm
HP Chromebook 13 G1 ¦ HP Elite x2 1012 G1, 1012 G2 ¦ HP EliteBook Folio G1 ¦ HP MX12 Retail Solution ¦ HP Pro x2 612 G2 ¦ HP ProBook 440 G4 Notebook, 440 G6 Notebook, 450 G6 Notebook, 455 G4 Notebook ¦ HP Spectre Pro 13 G1 ¦ HP x2 210 G2
Brand: HPE
