HPE HP 3800-24SFP-2SFP+ Switch
Quicklinx: 9136WS00 Mfr#: J9584A
The HPE 3800 Switch Series provides performance, resiliency, flexibility, and ease of use for enterprise edge, SMB and branch office deployments. Based on a powerful ProVision ASIC, the switch has low latency, increased packet buffering, and adaptive power consumption. Mesh-stacking technology delivers modular chassis-like resiliency in stackable 1U form factor. The HPE 3800 Switch Series has a robust Layer 3 feature set with IPv6, IPv4 BGP, policy based routing, and OSPF. It is SDN ready with OpenFlow support.
  • Performance, Resiliency and SDN Ready for the Campus Edge
    The Aruba 3800 Switch Series provides performance, resiliency, flexibility, and ease of use for enterprise edge, SMB and branch office deployments.Full Layer 3 switch series for flexible deployment with 24 or 48 Gigabit Ethernet ports plus convenient built-in 10GbE uplinks (10GBASE-T or SFP+), PoE+, Energy Efficient Ethernet, and hot-swappable, redundant power supplies.Mesh-stacking technology delivers modular chassis-like resiliency in stackable 1U form factor with optional stacking modules.License free software with advanced Layer 2 and 3 feature set including IPv4 BGP, policy based routing, IPv4/IPv6 OSPF, and robust QoS.Delivers consistent wired/wireless user experience with unified management tools such as ClearPass Policy Manager and Airwave Network Management. Provides optimal configuration automatically when connected to Aruba AP's for PoE priority, VLAN configuration, and rogue AP containment.
  • Mesh Stacking and Power at the Edge
    The Aruba 3800 Switch Series uses a powerful ProVision ASIC providing very low latency, increased packet buffering, and adaptive power consumption.Meshed-stacking technology delivers high-performance stacking with up to 336 Gbps of throughput and increased resiliency.As many as five 3800 switches can be stacked in a mesh topology and then an additional five can be arranged in a ring.Selectable queue configurations enables increased performance by selecting the number of queues and associated memory buffering that best meet the requirements of the network applications.
  • Resiliency and High Availability
    The Aruba 3800 Switch Series supports virtual router redundancy protocol (VRRP) allowing groups of two routers to dynamically back each other up to create highly available router environments in both IPv4 and IPv6 networks.Uninterrupted switching and routing for improved support of applications such as unified communications and enhanced L3 high availability.Dual hot-swappable power supplies provide uninterrupted power and allow swapping of modules on the fly to reduce impact on the network availability. Provides up to 1080 W PoE+ power.
  • Robust Security and Quality of Service (QoS)
    The Aruba 3800 Switch Series includes a robust set of security and QoS features to build a network that meets ever-changing corporate policies and compliances.Flexible authentication options include Local MAC, 802.1X, MAC and Web modes for greater policy-driven application security.Advanced distributed denial of service (DDOS) protection-such as DHCP Snooping, IP Source Guard, and ARP Protection-flexible traffic control programs, policy-based routing, QoS, and ACL, manage end-to-end application priorities.Powerful multilevel-access security controls, such as varying security management login, RADIUS/TACACS+, and SSH increase security and control change management access.Supports ClearPass Policy Manager for unified and consistent policy between wired and wireless users and simplifies implementation and management of guest login, user onboarding, network access, security, QoS, and other network policies.
HPE Aruba 3800-24SFP-2SFP+ - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L4 - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x Gigabit SFP + 2 x 10 Gigabit Ethernet / 1 Gigabit Ethernet SFP+
Performance
Throughput: 65.4 Mpps , Switching capacity: 88 Gbps
Routing table entries: 10000
MAC Address Table Size
65500 entries
Jumbo Frame Support
Routing Protocol
OSPF, RIP-1, RIP-2, IGMP, VRRP, OSPFv2, PIM-SM, static IP routing, PIM-DM, OSPFv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, CLI
Flow control, Layer 2 switching, DHCP support, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DiffServ support, IPv6 support, sFlow, Rapid Spanning Tree Protocol (RSTP) support, Virtual Route Redundancy Protocol (VRRP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, STP Root Guard, Uni-Directional Link Detection (UDLD), fan tray, MAC address lockout
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1v, IEEE 802.3an
Power Redundancy
Optional
44.3 cm x 46.7 cm x 4.3 cm
7.3 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
65500 entries
Jumbo Frame Support
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
2
RAM
2 GB SDRAM
Flash Memory
4 GB
24 x 100Base-TX/1000Base-T - SFP (mini-GBIC) , 2 x 10Gb Ethernet - SFP+ , 1 x console RJ-45 management , 1 x RJ-45 management
Expansion Slots
1 (total) / 1 (free) x Stacking Module
Installed Qty
1
Max Supported Qty
2
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Rack Mounting Kit
Included
FCC Class A certified, CISPR 24, EN 61000-3-2, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, EN 61000-3-3, UL 60950, CSA 22.2 No. 60950, RoHS, IEC 60950-1, EN 60950-1, EN 60825
44.3 cm
46.7 cm
4.3 cm
7.3 kg
45 °C
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
15 - 90% (non-condensing)
9136 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
