HPE HP 3600-48-PoE+ v2 SI Switch
Quicklinx: B9PFWS00 Mfr#: JG307B
The HP 3600 SI Switch Series delivers resiliency, security, and reliability at the enterprise edge. This Basic Layer 3 Fast Ethernet switch series supports IRF stacking, Static & RIP Routing, ACLs, IPv6, and PoE+. The HP 3600 SI Switch Series can be managed with the optional HP Intelligent Management Center (IMC) Software Platform for a single view of your entire network and includes a Limited Lifetime Warranty 2.0 with 3 years 24x7 phone support.
  • Resilient Basic Layer 3 Fast Ethernet Access Layer Switches
    The HPE 3600 SI Switch Series delivers resiliency, security, and reliability at the enterprise edge.The 3600 SI Switch Series comes with 24 or 48 ports switching at 10/100 and 4 SFP Gigabit Ethernet ports for stacking and uplinks and up to 720 W of PoE+ power with external EPS/RPS.Hewlett Packard Enterprise Intelligent Resilient Fabric (IRF) virtualizes up to nine physical switches into one logical device for simpler, flatter, and more agile networks.Basic Layer 3 features include support for static and RIP routing.Limited Lifetime Warranty and no software licensing required.
  • Enhanced Quality of Service (QoS)
    The HPE 3600 SI Switch Series supports advanced, classifier-based QoS which directs traffic using multiple match criteria based on Layer 2, 3, and 4 information. These switches apply QoS policies such as setting priority level and rate limit to selected traffic on a per-port or per-VLAN basis.Provides traffic prioritization with congestion actions: strict priority (SP), weighted round robin (WRR), weighted fair queuing (WFQ), and weighted random early discard (WRED).
  • Integrated and Distributed Security Enforcement
    The HPE 3600 SI Switch Series supports flexible authentication methods including 802.1X, and MAC and Web for greater, policy-driven application security.Identity-driven security and access control with automatic VLAN assignment and per-user ACLs allows access to specific network services without risking network security.Security features include: IP source guard, STP BPDU port protection, and RADIUS/HWTACACS.
  • Single View of the Network
    The HPE 3600 SI Switch Series can be seamlessly managed with the optional HPE Intelligent Management Center (IMC) Software Platform to provide end-to-end network transparency with consistent network experience through comprehensive configuration, compliance and policy management.RMON and sFlow provides advanced monitoring and reporting capabilities for statistics, history, alarms, and events.
HPE 3600-48-PoE+ v2 SI - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
48 x 10/100 (PoE+) + 4 x Gigabit SFP + 2 x shared 10/100/1000
Power Over Ethernet (PoE)
PoE+
PoE Budget
720 W
Performance
Throughput: 13.1 Mpps , Routing/switching capacity: 17.6 Gbps
IPv4 routing table entries: 2048
Jumbo Frame Support
9216 bytes
Routing Protocol
RIP-1, RIP-2, IGMP, VRRP, static IPv4 routing, static IPv6 routing, RIPng, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, SSH-2, CLI
Flow control, routing, Layer 2 switching, DHCP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, IPv6 support, sFlow, STP support, RSTP support, VRRP support, MSTP support, TFTP support, ACL support, QoS, CAR, Jumbo Frames support, MLD snooping, DLDP support, RRPP, BFD, EAD, STP Root Guard, dynamic ARP protection, GARP, IRF technology
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1v, IEEE 802.1ab (LLDP), IEEE 802.3at
43.99 cm x 42.01 cm x 4.37 cm
10 kg
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE+
PoE Budget
720 W
Performance
Jumbo Frame Support
9216 bytes
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, Secure Shell v.2 (SSH2), HWTACACS
RAM
256 MB SDRAM
Flash Memory
128 MB
48 x LAN RJ-45 PoE+ , 4 x Gigabit LAN SFP , 2 x 1000Base-T RJ-45 , 1 x serial (console) RJ-45
Internal power supply
820 Watt
Rack Mounting Kit
Included
FCC Class A certified, CISPR 22 Class A, EN 61000-3-2, EN 61000-3-3, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EMC, ICES-003 Class A, EN 61000-4-5, EN 61000-4-11, RoHS, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, CSA C22.2 No. 60950-1, EN 60825-1, EN 60825-2
43.99 cm
42.01 cm
4.37 cm
10 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day
50 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
B9PF C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.68
B9PF C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.87
