The HP 3600 EI Switch Series delivers resiliency, security, and reliability at the enterprise edge with support for advanced Layer 3 and multicast routing. This advanced Layer 3 Fast Ethernet switch series has a robust feature set supporting IRF stacking, Static & RIP Routing, OSPF, BGP, IS-IS, PoE+, ACLs, and IPv6. The HP 3600 EI Switch Series can be managed with the optional HP Intelligent Management Center (IMC) Software Platform for a single view of your entire network and includes a Limited Lifetime Warranty 2.0 with 3 years 24x7 phone support.
Resilient and Reliable Fast Ethernet Access Layer Switches
The HPE 3600 EI Switch Series delivers resiliency, security, and reliability at the enterprise edge with support for advanced Layer 3 and multicast routing.Designed for increased flexibility and scalability, the 3600 EI Switch Series comes with 24- or 48-10/100 ports and 4 SFP Gigabit Ethernet ports for stacking and uplinks, a 24-port 100BASE-FX switch with 2 or 4 Gigabit Ethernet SFP slots and models with 370 W of PoE+ power.Hewlett Packard Enterprise Intelligent Resilient Fabric (IRF) virtualizes up to nine physical switches into one logical device for simpler, flatter, more agile networks.Enterprise class features include Dynamic and Multicast Routing, RIP, OSPF, BGP, PIM, and ECMP.Limited Lifetime Warranty and no software licensing required. -
Powerful Quality of Service (QoS)
The HPE 3600 EI Switch Series supports advanced, classifier-based QoS which directs traffic using multiple match criteria based on Layer 2, 3, and 4 information and applies QoS policies such as setting priority level and rate limit to selected traffic on a per-port or per-VLAN basis.Provides extensive traffic prioritization with congestion actions: strict priority (SP), weighted round robin (WRR), weighted fair queuing (WFQ), and weighted random early discard (WRED). -
Integrated and Distributed Security Enforcement
The HPE 3600 EI Switch Series supports flexible authentication methods including 802.1X, MAC, and Web for greater, policy-driven application security.Identity-driven security and access control with automatic VLAN assignment and per-user ACLs allows access to specific network services without risking network security.Security features include: IP source guard, STP BPDU port protection, and RADIUS/HWTACACS. -
Single View of the Network
The HPE 3600 EI Switch Series can be seamlessly managed with the optional HPE Intelligent Management Center (IMC) Software Platform to provide end-to-end network transparency with consistent network experience through comprehensive configuration, compliance and policy management.RMON and sFlow provides advanced monitoring and reporting capabilities for statistics, history, alarms, and events.
- HPE 3600-48-PoE+ v2 EI - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- 48 x 10/100 (PoE+) + 4 x Gigabit SFP + 2 x shared 10/100/1000
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 320 W
- Performance
- Throughput: 13.1 Mpps , Routing/switching capacity: 17.6 Gbps
- Capacity
- IPv4 routing table entries: 12000
- MAC Address Table Size
- 32000 entries
- Jumbo Frame Support
- 9216 bytes
- Routing Protocol
- OSPF, RIP-1, RIP-2, IGMPv2, IGMP, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, OSPFv3, PIM-SSM, MSDP, static IPv4 routing, static IPv6 routing, ECMP, RIPng, BGP-4+
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2, CLI
- Flow control, DHCP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, IPv6 support, half duplex mode, full duplex mode, sFlow, STP support, RSTP support, VRRP support, MSTP support, TFTP support, ACL support, QoS, CAR, Jumbo Frames support, MLD snooping, DLDP support, RRPP, BFD, EAD, STP Root Guard, IPv4 support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1v, IEEE 802.1ab (LLDP), IEEE 802.3at
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 42 cm x 4.36 cm
- 10 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- PoE+
- PoE Budget
- 320 W
- Performance
- Capacity
- 32000 entries
- 9216 bytes
- Routing Protocol
- Encryption Algorithm
- SSL
- Authentication Method
- Secure Shell (SSH), RADIUS, Secure Shell v.2 (SSH2), HWTACACS
- RAM
- 256 MB SDRAM
- Flash Memory
- 128 MB
- 48 x 100Base-TX RJ-45 PoE+ , 4 x Gigabit LAN SFP , 2 x 1000Base-T RJ-45 , 1 x serial (console) RJ-45 management
- Power Device
- Internal power supply
- Voltage Required
- 440 Watt
- Rack Mounting Kit
- Included
- CISPR 22 Class A, EN 61000-3-2, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, EN 61000-3-3, EMC, ICES-003 Class A, RoHS, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, FCC Part 15 A, CSA C22.2 No. 60950-1, EN 60825-1, ANSI C63.4-2003, EN 60825-2, EN 300 386
- 44 cm
- 42 cm
- 4.36 cm
- 10 kg
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.71 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.87 |
HPE X120 1G SFP LC LX Transceiver | In Stock | £355.96 |
HPE Premier Flex LC/LC OM4 2f 1m Cbl | In Stock | £46.43 |
HPE Premier Flex Network cable 5m Fibre Optic | In Stock | £34.07 |
