Solid State Drives (SSDs) are fast becoming a real force with respect to storage in the computer industry. With no moving parts, storage is no longer bound by mechanical barriers to higher performance. HP SSDs for workstations offer overall performance typcially beyond that of SAS 15k rpm HDDs (Hard Disk Drives).
- HP - SSD - 256 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 256 GB
- Form Factor
- 2.5" SFF (in 3.5" carrier)
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- 6.36 cm x 6.99 cm x 9.5 mm
- Designed For
- Workstation Z1, Z1 G3, Z2 G4, Z2 G5, Z2 Mini G3 Entry, Z2 Mini G3 Performance, Z2 Mini G4 Entry, Z2 Mini G4 High Performance, Z2 Mini G4 Performance, Z2 Mini G5, z210, Z220, Z230, Z238, Z4 G4, z400, Z420, z600, Z620, Z640 (2.5" SFF), Z8 G4, z800, Z820; ZCentral 4R
- Capacity
- 256 GB
- Form Factor
- 2.5" SFF
- Interface
- SATA 6Gb/s
- 6.36 cm
- 6.99 cm
- 9.5 mm
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 500 MBps
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5" SFF or 3.5" (with included bay adapter)
- Included Accessories
- 3.5-inch bay adapter
- 0 °C
- 70 °C
- Designed For
- HP Workstation Z1, Z1 G3, Z2 G4, Z2 G5, Z2 Mini G3 Entry, Z2 Mini G3 Performance, Z2 Mini G4 Entry, Z2 Mini G4 High Performance, Z2 Mini G4 Performance, Z2 Mini G5, z210, Z220, Z230, Z238, Z4 G4, z400, Z420, z600, Z620, Z640 (2.5" SFF), Z8 G4, z800, Z820 , HP ZCentral 4R
