HPE HP 24-port Switch
Quicklinx: 8W2YWS00 Mfr#: J9663A
The HPE 1410 Switch Series consists of unmanaged switches designed for small businesses looking for entry-level, low-cost, reliable networking solutions. Available features include flow control to provide outstanding data efficiency, simplified plug-and-play operation, Auto-MDIX, auto-speed negotiation, flexible mounting options, and Limited Lifetime Warranty. All models have Quality of Service (QoS) support and IEEE 802.3x flow control features. Plug-and-play convenience is enabled by auto-MDIX and auto-speed negotiation.
  • Ease of Use
    The HPE OfficeConnect 1410 Switch Series offers unmanaged plug-and-play simplicity.Comprehensive LED display with per-port indicators provides an at-a-glance view of status, activity, speed, and full-duplex operation.Auto-speed negotiation automatically selects individual port speed depending on client capabilities without the need for manual intervention.Flow control helps provide reliable communications during full-duplex operation.
  • Connectivity and Performance
    The HPE OfficeConnect 1410 Switch series provides automatic cable type detection for MDI/MDIX.These switches support Jumbo or Mini-Jumbo packets (based on model) for performance improvement of large data transfers.They double the throughput of every port with Half/Full duplex auto-negotiating capabilities.
  • Quality of Service (QoS)
    The HPE OfficeConnect 1410 Switch Series allows real-time traffic prioritization by supporting Differentiated Services Code Point (DSCP).IEEE 802.1p prioritization delivers data to devices based on the priority and type of traffic.They support energy-efficient Ethernet and allows lower power consumption when operated with IEEE-compliant client devices.
HPE OfficeConnect 1410 24 - switch - 24 ports - unmanaged - rack-mountable
Switch - 24 ports - L3 - unmanaged
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
24 x 10/100
Performance
Throughput: 3.5 Mpps , Switching capacity: 4.8 Gbps
MAC Address Table Size
8K entries
Jumbo Frame Support
9216 bytes
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, QoS, fanless, Mini Jumbo Frame support
IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
33.6 cm x 16.9 cm x 4.4 cm
1.35 kg
Enclosure Type
Desktop, rack-mountable, wall-mountable
Subtype
Fast Ethernet
Ports
24 x 10/100
Performance
8K entries
Jumbo Frame Support
9216 bytes
24 x 100Base-TX RJ-45
External power adapter
Rack Mounting Kit
Included
FCC Class A certified, CISPR 24, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN55024, CISPR 22, CSA 22.2 No. 60950, FCC Part 15 B, UL 60950-1, IEC 60950-1, EN 60950-1
33.6 cm
16.9 cm
4.4 cm
1.35 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
15 - 90%
8W2Y C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
