The 1U Rackmount Keyboard with USB combines a full size keyboard with a new touchpad in a 1U format with room to mount an HP KVM Switch behind it. The 1U Keyboard includes a three button touch pad with a scroll bar, 4 cursor keys, and Windows shortcut keys. The 1U Keyboard provides PS2 and USB connectivity and a USB port on the front of the keyboard for USB pass through with compatible KVM switches. New silver color and front LEDs ease unit identification when closed in high density racks.
Space saving design
The 1U rackmount keyboard with USB combines a full size keyboard with touch pad in a 1U format with enough room to mount an HP KVM switch behind it. -
Front LEDs
Front LEDs ease unit identification when closed in high density racks. -
Enhanced connectivity
USB and PS2 connectivity allows a variety of connection possibilities. -
3-button touchpad with scrolling
Located below the space bar for a centrally located input device. -
Four scroll keys
Located between the keyboard and numeric keypad for easy access. -
Toolless rails
Snap-in rails ease installation.
- HPE 1U Rackmount Keyboard with USB - keyboard - UK - silver
- Keyboard - rack-mountable
- Interface
- PS/2, USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Integrated touchpad
- Silver
- 43.2 cm x 42.3 cm x 4.2 cm
- 2.7 kg
- 3-year warranty
- Designed For
- Integrity BL60; ProLiant BL20p G3, BL20p G4, BL25, BL30, BL35, BL45, BL45p G2, BL460, BL480, DL120 G6, DL320 G5p, DL320 G6, DL360 G5, DL365, DL365 G5, DL380 G4, DL380 G5, DL380 G6, DL385, DL385 G2, DL385 G5, DL385 G5p, DL580 G4, DL585 G2, DL585 G6, DL785 G5, DL785 G6, ML350 G5, ML370 G5, ML570 G4
- Interface
- PS/2, USB
Input Device
- UK
- Region
- United Kingdom
- 43.2 cm
- 42.3 cm
- 4.2 cm
- 2.7 kg
- 1 x USB
- Connections
- 1 x USB , 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style)
- Silver
- Limited warranty - parts - 3 years
- 0 °C
- 35 °C
- 20 - 90%
- Designed For
- HPE Integrity BL60p , HPE ProLiant BL20p, BL20p G2, BL20p G3, BL20p G4, BL25p, BL30p, BL35p, BL40p, BL45p, BL45p G2, BL460c, BL480c, DL120 G6, DL120 G6 Base, DL120 G6 Performance, DL320 G5p, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G5, DL360 G5 Base, DL360 G5 Entry, DL360 G5 Performance, DL365 Base, DL365 Entry, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL365 Performance, DL380 G4, DL380 G5, DL380 G5 Base, DL380 G5 Entry, DL380 G5 High Performance, DL380 G5 Storage Server 2TB SATA Model, DL380 G6 Entry, DL385, DL385 G2 Base, DL385 G2 Entry, DL385 G2 High Performance, DL385 G5, DL385 G5 Base, DL385 G5 Entry, DL385 G5 Performance, DL385 G5p Base, DL385 G5p High Performance, DL580 G4 High Performance, DL585 G2, DL585 G6, DL585 G6 Base, DL785 G5, DL785 G6, DL785 G6 Base, DL785 G6 Performance, ML350 G5, ML350 G5 Base, ML350 G5 Entry, ML370 G5, ML370 G5 Base, ML370 G5 Entry, ML370 G5 Performance, ML570 G4, ML570 G4 High Performance
