Serial Attached SCSI (SAS) provides a superior storage solution. With some storage requirements escalating and others becoming more complex, factors such as flexibility, performance, increased reliability, greater density, security, scalability and accessibility are more critical than ever.
SAS Midline hard drives are ideal for servers or external storage for high-capacity, non mission-critical environments with less than 40% workloads requiring economical reliability (about twice that of entry drives) and redundant data paths to the drive, e.g. disk backup, archival, reference, and other highly available applications.
- HPE Dual Port Midline - hard drive - 1 TB - SAS
- Hard drive - hot-swap
- Capacity
- 1 TB
- Form Factor
- 3.5" LFF
- Interface
- SAS
- Data Transfer Rate
- 300 MBps
- Spindle Speed
- 7200 rpm
- 1-year warranty
- Designed For
- ProLiant DL160 G6 (3.5"), DL180 (3.5"), DL180 G5 (3.5"), DL180 G5 Special Server (3.5"), DL180 G6 (3.5"), DL185 G5 (3.5"), DL380 G6 (3.5"), DL380 G6 Performance (3.5"), ML110 G6 (3.5"), ML350 (3.5"), ML350 G5 (3.5"), ML350 G5 Base (3.5"), ML350 G5 Entry (3.5"), ML350 G6 (3.5")
- Capacity
- 1 TB
- Form Factor
- 3.5" LFF
- Interface
- SAS
Performance
- Drive Transfer Rate
- 300 MBps (external)
- Spindle Speed
- 7200 rpm
Expansion & Connectivity
- 1 x SAS
- Compatible Bay
- 3.5" LFF
- Limited warranty - 1 year
- Designed For
- HPE ProLiant DL160 G6 (3.5"), DL180 (3.5"), DL180 G5 (3.5"), DL180 G5 Special Server (3.5"), DL180 G6 (3.5"), DL185 G5 (3.5"), DL380 G6 (3.5"), DL380 G6 Performance (3.5"), ML110 G6 (3.5"), ML350 (3.5"), ML350 G5 (3.5"), ML350 G5 Base (3.5"), ML350 G5 Entry (3.5"), ML350 G6 (3.5")
