Get stable 2D and advanced 3D graphics performance from the AMD Radeon HD 8350 PCIe x16 DH GFX, a low profile, PCI Express x16 graphics add-in card based on the AMD Radeon HD 8350 GPU, great for Web conferencing or video and photo editing.
- AMD Radeon HD 8350 - graphics card - Radeon HD 8350 - 1 GB
- Graphics card
- Bus Type
- PCI Express 2.1 x16
- Graphics Engine
- Memory
- 1 GB DDR3
- Effective Memory Clock
- 875 MHz
- Memory Interface
- 64-bit
- API Supported
- DirectX 11, OpenGL 4.0
- 15.6 cm x 6.89 cm
- Designed For
- ProDesk 400 G1, 400 G2
- Graphics card
- Bus Type
- Graphics Engine
- API Supported
- AMD Unified Video Decoder (UVD) 2, Shader Model 5.0, AMD HD Media Accelerator
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 875 MHz
- Bus Width
- 64-bit
- Bandwidth
- 12.8 GBps
- OS Required
- Red Hat Enterprise Linux, Microsoft Windows 7 Professional (32/64 bits), Windows 8, Windows 8 Pro, SUSE Linux Enterprise Desktop 11 (32/64-bit)
- 20 Watt
- UL, VCCI, C-Tick, BSMI, FCC, KCC, CISPR, ICES
- 15.6 cm
- 6.89 cm
- Designed For
- HP ProDesk 400 G1, 400 G2
