Your basket is empty
HPE HP 1420-24G-POE+ (124W) Switch
Quicklinx: B9WXWS00 Mfr#: JH019A
Type: Gigabit Ethernet
Ports: 24
Managed: No
POE: PoE+
£304.23 ex VAT
£365.07 inc VAT
The HPE 1420 Switch Series consists of unmanaged Gigabit Ethernet switches for small businesses and others looking for plug-and-play basic Layer 2 connectivity for their network, including low-cost PoE+ and 10GbE uplink models. The HPE 1420 Switch Series has four models: 16-port 10/100/1000, 24-port 10/100/1000 with two SFP Gigabit ports, 24-port 10/100/1000 ports of which 12 are PoE+ enabled (124 W PoE budget), and 24-port 10/100/1000 with two SFP+ 10GbE ports. All are fanless. They come with a limited lifetime warranty and 24X7 phone support for 90 days.
HPE 1420-24G-PoE+ (124W) Switch - switch - 24 ports - unmanaged - desktop, rack-mountable
Switch - 24 ports - unmanaged
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
12 x 10/100/1000 (PoE+) + 12 x 10/100/1000
Power Over Ethernet (PoE)
PoE+
PoE Budget
124 W
Performance
Throughput (64-byte packet size): up to 35.7 Mpps , Switching capacity: 48 Gbps
MAC Address Table Size
8192 entries
Jumbo Frame Support
9216 bytes
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, Quality of Service (QoS), fanless, 512KB packet buffer, DiffServ Code Point (DSCP) support
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at, IEEE 802.3az
44 cm x 23.8 cm x 4.4 cm
3.3 kg
Bundled Services
Enclosure Type
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
124 W
Performance
8192 entries
Jumbo Frame Support
9216 bytes
Flash Memory
1 MB
12 x 1000Base-T - RJ-45 - PoE+ , 12 x 1000Base-T - RJ-45
Internal power supply
MTBF
69.9 years
CISPR 24, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN55024, CISPR 22, CSA 22.2 No. 60950, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 B Class A
44 cm
23.8 cm
4.4 cm
3.3 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - phone consulting - 3 years
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
B9WX C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £4.30
B9WX C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.25
B9WX C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.51
B9WX C2G 2m Cat6a Shielded Patch - Blue In Stock £7.51
B9WX C2G TruLink Media Gateway RJ45 Cap In Stock £0.58
B9WX C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £47.56
Ports: 24
Managed: No
POE: PoE+
Brand: HPE
Price Range Ex VAT: 300 - 500
