HPE HP 12TB StorageWorks Network Storage System X1600 G2 NAS
Quicklinx: 7QZQWS00 Mfr#: BV861A
  • Xeon
HP X1600 G2 Network Storage Systems deliver high capacity and high performance and drives down your cost per GB. Quad-core processing, large internal storage capacity, and ready external expandability enhance this ultra-dense 2U shared storage solution for small, medium, or large IT environments. The X1600 G2 is built with a special motherboard supporting iLO2 remote management.
  • Manage, expand, and protect a single centralized storage system
    Consolidate islands of direct-attached or network attached storage to one easy-to-use Windows-powered shared storage platform. Since it's versatile unified storage, it can be a file server, an iSCSI target for application/virtual environment storage, or both.
  • Go from out-of-the-box to sharing storage in minutes, not hours
    The Windows-powered operating system is pre-installed and user storage is easy to provision with HP ASM, so you can add storage to your network quickly and securely.
  • Seamless integration into your Windows environment
    It's running Windows, so it integrates natively into your Windows Active Directory (AD) and Distributed File System (DFS) environments, runs your favorite antivirus, backup, and storage management applications, and the Microsoft Management Console (MMC) user interface has a familiar look and feel.
  • Remote and enterprise manageability
    You can manage and troubleshoot from outside the office at both the operating system level and at the platform level.
HPE StorageWorks Network Storage System X1600 G2 - NAS server - 12 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
12 TB
12 (installed) / 12 (max)
44.8 cm x 69.9 cm x 8.8 cm
19.2 kg ()
1 x Intel Xeon E5520 2.26 GHz (Quad-Core)
Storage Controller
RAID PCIe 2.0 x8 SATA 3Gb/s / SAS 6Gb/s RAID RAID 0, 1, 5, 6, 10, 50, 60
Hard Drive
6 x 2 TB SATA 3Gb/s
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
RAM
6 GB
Power Redundancy
Storage Operating System
Microsoft Windows Storage Server 2008 Standard x64 Edition
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
12 TB
44.8 cm
69.9 cm
8.8 cm
19.2 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
2
RAM
6 GB (installed) / 32 GB (supported)
Storage Controller
RAID - internal
Bus Type
PCI Express 2.0 x8
Interface Type
Data Transfer Rate
600 MBps
Supported Devices
Disk array (RAID)
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Hard Drive
HDD - hot-swap - 3.5" LFF
6 x 2 TB
Interface Type
SATA 3Gb/s
Network / Transport Protocol
TCP/IP
Network Services Compatibility
Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), HTTP
Expansion Bays
12 (total) / 6 (free) x hot-swap - 3.5" LFF
Expansion Slots
12 (total) / 9 (free) , 2 (total) / 1 (free) x PCI Express 2.0 x8 , 1 (total) / 1 (free) x PCI Express 2.0 x16 , 1 (total) / 1 (free) x PCI Express 2.0 x8
2 x Ethernet 1000Base-T - RJ-45 , 6 x USB 2.0 - Type A , 1 x VGA - HD-15 , 1 x serial , 1 x keyboard , 1 x mouse
EN 60950, EN 61000-3-2, EN55022, IEC 60950, EN 61000-3-3, EN55024, CISPR 22
Power Redundancy
Power Provided
750 Watt
10 °C
35 °C
10 - 90%
