HPE 120GB 6GB SATA 2.5IN RI-PLP SC
Quicklinx: C0NDWS00 Mfr#: 804581-B21
Do you need to accelerate the performance of your data-intensive application workloads? HPE Server Read Intensive (RI) Solid State Drives (SSDs) deliver high performance and endurance while reducing power consumption for customers with applications requiring high random read and write IOPs performance. HPE RI SSDs offer the highest performance for read intensive applications and typically have an endurance of <1 drive writes per day. All HPE SSDs are backed by over 2.4 million hours of the industry's most rigorous testing and qualification program ensuring reliable, high performing drives. HPE integrated firmware protects data from malicious attacks that could change or destroy it. The self-describing icons on the HPE SMART Carrier takes the guess work out of a drive's status and a "do not remove" button prevents data loss from human error. You can monitor the lifespan of your SSD with HPE SmartSSD Wear Gauge compatibility in management tools.
  • High Performance, Exceptional Reliability and Efficiency for Faster Business Results
    HPE Server Read Intensive (RI) Solid State Drives (SSD) are ideal for Big Data Analytics, Cloud Computing, Active Archiving, Database Applications and Data Warehousing.Achieve higher Input / Output per Second (IOPs) to enhance the performance of your data center.Maintains data accuracy with full data-path error detection.A broad portfolio of optimized solutions in capacities up to 1.6 TB and growing.12 GB SAS, 6 GB SATA, NVMe, M.2 and M.2 Enablement Kits.
HPE Read Intensive-2 - SSD - 120 GB - SATA 6Gb/s
Solid state drive - hot-swap
120 GB
2.5" SFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Power Loss support
15 mm
3-year warranty
Bundled with
HP SmartDrive carrier
Apollo 4200 Gen9; ProLiant DL120 Gen9, DL160 Gen8, DL160 Gen9, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen9, DL360e Gen8, DL360p Gen8, DL380 Gen9, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL388p Gen8, DL580 Gen9, DL60 Gen9, DL80 Gen9, ML110 Gen9, ML150 Gen9, ML310e Gen8, XL230a Gen9, XL250a Gen9
120 GB
2.5" SFF
SATA 6Gb/s
Power Loss support
15 mm
Bundled with
Performance
Drive Writes Per Day (DWPD)
1
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
480 MBps (read) / 135 MBps (write)
4KB Random Read
61500 IOPS
4KB Random Write
5400 IOPS
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" SFF
Power Consumption
9 Watt
Limited warranty - 3 years
60 °C
HPE Apollo 4200 Gen9 for Google (2.5") , HPE ProLiant DL120 Gen9 (2.5"), DL120 Gen9 Entry (2.5"), DL160 Gen9 (2.5"), DL160 Gen9 Base (2.5"), DL160 Gen9 Entry (2.5"), DL160 Gen9 Performance (2.5"), DL180 Gen9 (2.5"), DL180 Gen9 Base (2.5"), DL180 Gen9 Entry (2.5"), DL180 Gen9 Storage (2.5"), DL20 Gen9 (2.5"), DL20 Gen9 Entry (2.5"), DL20 Gen9 Performance (2.5"), DL320e Gen8 Base (2.5"), DL320e Gen8 Entry (2.5"), DL320e Gen8 Performance (2.5"), DL320e Gen8 Special Server (2.5"), DL320e Gen8 v2 (2.5"), DL320e Gen8 v2 Base (2.5"), DL320e Gen8 v2 Entry (2.5"), DL320e Gen8 v2 Performance (2.5"), DL360 Gen9 (2.5"), DL360 Gen9 Base (2.5"), DL360 Gen9 CMS (2.5"), DL360 Gen9 Entry (2.5"), DL360 Gen9 High Performance (2.5"), DL360 Gen9 Performance (2.5"), DL360 Gen9 Special Server (2.5"), DL360e Gen8 Special Server (2.5"), DL360p Gen8 (2.5"), DL360p Gen8 CMS (2.5"), DL360p Gen8 Performance (2.5"), DL360p Gen8 Special Server (2.5"), DL380 Gen9 (2.5"), DL380 Gen9 Base (2.5"), DL380 Gen9 Entry (2.5"), DL380 Gen9 High Performance (2.5"), DL380 Gen9 Performance (2.5"), DL380p Gen8 Performance (2.5"), DL385p Gen8 Entry (2.5"), DL385p Gen8 Storage Centric (2.5"), DL388p Gen8 Base (2.5"), DL580 Gen9 (2.5"), DL580 Gen9 Database (2.5"), DL580 Gen9 SAP HANA Scale-out Base Configuration (2.5"), DL580 Gen9 SAP HANA Scale-up Base Configuration (2.5"), DL60 Gen9 (2.5"), DL60 Gen9 Base (2.5"), DL60 Gen9 Entry (2.5"), DL80 Gen9 (2.5"), DL80 Gen9 Base (2.5"), DL80 Gen9 Entry (2.5"), ML110 Gen9 (2.5"), ML110 Gen9 Base (2.5"), ML110 Gen9 Entry (2.5"), ML150 Gen9 (2.5"), ML150 Gen9 Base (2.5"), ML150 Gen9 Entry (2.5"), ML150 Gen9 Performance (2.5"), ML310e Gen8 Base (2.5"), ML310e Gen8 v2 (2.5"), ML310e Gen8 v2 Base (2.5"), ML310e Gen8 v2 Enty (2.5"), ML310e Gen8 v2 Performance (2.5"), XL230a Gen9 Compute Tray (2.5"), XL230a Gen9 Compute Tray (12G) (2.5"), XL230a Gen9 Compute Tray (6G) (2.5"), XL250a Gen9 Accelerator Tray (2.5")
