Smart design allows you to charge up ten batteries from select HP 2011 and 2012 Business Notebooks Batteries simultaneously.
LEDs on the face of the charger indicate that the unit is powered and help you monitor individual battery charging status.
- HP 10-Bay Battery Charger - battery charger
- Battery charger - external
- 5 kg
- Batteries Qty
- 10 (supported)
- 55.5 cm x 22.5 cm x 17 cm
- 1-year warranty
- Designed For
- HP CC06XL, CC09, MT06 Mini Battery, SX09, VH08XL
- Supported Battery Technology
- Lithium Ion
- Quantity
- 10 (supported)
- 10 LED lights
- Limited warranty - 1 year
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- 55.5 cm
- 22.5 cm
- 17 cm
- 5 kg
- Designed For
