Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
Performance and Reliability for Multiple Application Environments
HPE Server SAS Hard Drives deliver high reliability for mission-critical applications.Robust SAS interface (dual port, full duplex) for increased performance.HPE Smart Carrier for HPE ProLiant Servers (both Gen8 and Gen9 are supported). They maintain backward compatibility with existing standard hot-plug carriers to provide support for HPE ProLiant G7 and earlier servers and server storage enclosures.They are ideal for transaction processing, database applications, analytics, high-performance computing and business applications.The 512e Advance Format Drive is ideal for 4KiB aligned operating systems and applications. They also support legacy 512K native applications.
- HPE Dual Port Enterprise - hard drive - 1.2 TB - SAS 6Gb/s
- Hard drive - hot-swap
- Capacity
- 1.2 TB
- Form Factor
- 2.5" SFF
- Interface
- SAS 6Gb/s
- Data Transfer Rate
- 600 MBps
- Spindle Speed
- 10000 rpm
- 75.7 mm x 118.7 mm x 15.6 mm
- 3-year warranty
- Bundled with
- HP SmartDrive carrier
- Designed For
- ProLiant BL460c Gen8, BL465c Gen8, BL660c Gen8, BL660c Gen9, DL160 Gen8, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen9, DL360p Gen8, DL380 Gen9, DL380p Gen8, DL385p Gen8, DL388p Gen8, DL560 Gen8, DL560 Gen9, DL580 Gen9, ML110 Gen9, ML30 Gen9, ML310e Gen8, ML350 Gen9, ML350e Gen8, ML350p Gen8, SL230s Gen8, SL250s Gen8, WS460c Gen8, WS460c Gen9, XL170r Gen9, XL190r Gen9
- Capacity
- 1.2 TB
- Form Factor
- 2.5" SFF
- Interface
- SAS 6Gb/s
- Bytes per Sector
- 512
- 75.7 mm
- 118.7 mm
- 15.6 mm
- Bundled with
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Seek Time
- 8.9 ms (max)
- Track-to-Track Seek Time
- 0.3 ms
- Average Latency
- 4.6 ms
- Spindle Speed
- 10000 rpm
Expansion & Connectivity
- 2 x SAS 6Gb/s
- Compatible Bay
- 2.5" SFF
- Limited warranty - 3 years
- 10 °C
- 35 °C
- Designed For
- HPE ProLiant BL460c Gen8 (2.5"), BL660c Gen8 (2.5"), BL660c Gen8 Performance (2.5"), BL660c Gen9 (2.5"), DL180 Gen9 (2.5"), DL180 Gen9 Base (2.5"), DL180 Gen9 Entry (2.5"), DL180 Gen9 Storage (2.5"), DL20 Gen9 (2.5"), DL20 Gen9 Entry (2.5"), DL20 Gen9 Performance (2.5"), DL320e Gen8 (2.5"), DL320e Gen8 Base (2.5"), DL320e Gen8 Entry (2.5"), DL320e Gen8 Performance (2.5"), DL320e Gen8 v2 (2.5"), DL320e Gen8 v2 Base (2.5"), DL320e Gen8 v2 Performance (2.5"), DL360 Gen9 CMS (2.5"), DL360 Gen9 Entry (2.5"), DL360p Gen8 (2.5"), DL360p Gen8 CMS (2.5"), DL360p Gen8 Performance (2.5"), DL360p Gen8 Special Server (2.5"), DL380 Gen9 (2.5"), DL380 Gen9 Base (2.5"), DL380 Gen9 Entry (2.5"), DL380 Gen9 Performance (2.5"), DL380p Gen8 Performance (2.5"), DL385p Gen8 Entry (2.5"), DL385p Gen8 Storage (2.5"), DL385p Gen8 Storage Centric (2.5"), DL388p Gen8 Base (2.5"), DL560 Gen8 (2.5"), DL560 Gen8 Base (2.5"), DL560 Gen8 Entry (2.5"), DL560 Gen8 Performance (2.5"), DL560 Gen9 (2.5"), DL560 Gen9 Base (2.5"), DL560 Gen9 Entry (2.5"), DL560 Gen9 Performance (2.5"), DL580 Gen9 (2.5"), DL580 Gen9 Database (2.5"), DL580 Gen9 SAP HANA Scale-out Base Configuration (2.5"), DL580 Gen9 SAP HANA Scale-up Base Configuration (2.5"), ML110 Gen9 (2.5"), ML110 Gen9 Base (2.5"), ML110 Gen9 Entry (2.5"), ML30 Gen9 (2.5"), ML30 Gen9 Base (2.5"), ML30 Gen9 Performance (2.5"), ML310e Gen8 (2.5"), ML310e Gen8 Base (2.5"), ML310e Gen8 Entry (2.5"), ML310e Gen8 Performance (2.5"), ML310e Gen8 v2 (2.5"), ML310e Gen8 v2 Base (2.5"), ML310e Gen8 v2 Enty (2.5"), ML310e Gen8 v2 Performance (2.5"), ML350 Gen9 (2.5"), ML350 Gen9 Base (2.5"), ML350 Gen9 Entry (2.5"), ML350 Gen9 Performance (2.5"), ML350e Gen8 v2 (2.5"), ML350p Gen8 (2.5"), ML350p Gen8 Special Server (2.5"), SL250s Gen8 Left Tray (2.5"), SL250s Gen8 Right Tray (2.5"), WS460c Gen8 (2.5"), WS460c Gen9 Graphics (2.5"), WS460c Gen9 Graphics Expansion (2.5"), XL170r Gen9 (2.5"), XL190r Gen9 (2.5")
