Boost the capabilities of your HP Workstation and improve system performance and application responsiveness with low-power, high-speed DDR4 memory from HP.
Flexible, fast scalability
Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between them with super-fast memory that you can scale to meet your exact requirements. -
HP-tested
Ensure that all of your memory characteristics match by upgrading with HP-branded memory that's been tested for seamless system-level integration with HP Workstations. -
Supported by HP
Protect your investment with the same world-class HP limited warranty you get for your HP Workstation.
- HP - DDR4 - module - 8 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - unbuffered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL15
- Unbuffered
- Voltage
- 1.2 V
- OEM Manufacturer Equivalent Part Number
- HP 840817-001, HP T0E51AT
- Manufacturer Selling Program
- HP Smart Buy
- Designed For
- Workstation Z238, Z240
- Capacity
- 8 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL15
- Non-ECC
- Unbuffered
- Chips Organization
- 512 x 8
- Voltage
- 1.2 V
- HP Smart Buy
- Designed For
- HP Workstation Z238, Z240
