HPE External USB Optical Drive
Quicklinx: 9RF9WS00 Mfr#: F2B56AA
  • DVD-RW
Connect the HP External USB DVD/RW to any available USB port on your PC to get immediate read/write access to your optical media.
  • USB plug and play
    No power adapter needed. The USB cable connects to your PC's USB 2.0 or 3.0 ports allowing for easy data transfer and constant power for the external drive.
  • OS compatible
    Conveniently works with the Windows 7, Windows 8 and Windows 10, Mac 10.4 or later and Chrome operating systems, so navigate and create with familiarity.
  • Media storage
    Create your own DVD movies, music CDs, or store that big presentation. The dual layer technology allows you to store twice as much data up to 8.5 GB of storage.
  • Performance protection
    To offset data transfer interruptions and slowdowns the drive utilizes buffer under-run protection to eliminate writing errors.
HP DVD-RW drive - USB - external
DVD-RW drive - external
USB
Optical Storage
DVD-RW
HP 245 G10 Notebook; Elite x360 1040 G10 Notebook; EliteBook 830 G10 Notebook; Pro x360 Fortis 11 G11 Notebook
USB
Optical Storage
DVD-RW
HP 245 G10 Notebook , HP Elite x360 1040 G10 Notebook , HP EliteBook 830 G10 Notebook , HP Pro x360 Fortis 11 G11 Notebook
