HPE Ethernet 1GB 4-Port Adapter
Quicklinx: CLZJWS00 Mfr#: 629135-B22
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Compatibility: PC, Unix
Type: Network adapter
Hurry, only 1 left in stock!
£51.30 ex VAT
£61.56 inc VAT
Do you need a low power, high port density 1GbE network adapters for virtualization and server consolidation? The HPE Ethernet 1Gb 4-port 331FLR Adapter for select HPE ProLiant Gen8 and Gen9 rack servers features the next generation of Ethernet integration, offering a single-chip solution in a FlexibleLOM form factor, which offers the option for future upgrades to 10GbE networking speeds. It delivers full line-rate performance across all ports with low power consumption. The HPE 331FLR is ideal for virtualization, security, server consolidation, network segmentation, and other applications requiring maximum throughput and port density. The total aggregate throughput of 4 Gb meets the needs of customers desiring high bandwidth. The HPE 331FLR supports advanced features such as Large Send and Receive offload capability, TCP checksum and segmentation, VLAN tagging, MSI-X, jumbo frames, IEEE 1588, HPE Sea of Sensors 3D and virtualization features such as VMware NetQueue and Microsoft VMQ. Support for HPE Sea of Sensors 3D Technology enhances server performance while reducing energy use and expense.
  • Designed for Maximum Throughput and High Port Density
    Replaceable FLexibleLOM enables easy upgrade from 1GbE to 10GbE.An aggregate, full duplex transfer rate of 8 Gb/s per adapter delivers outstanding network performance that improves response time and removes bottlenecks.Comprehensive stateless offloads optimize host efficiency and VM density by leaving host CPU available for other duties.Virtualization support for VMware NetQueue and Microsoft VMQ help meet the performance demands of consolidated virtual workloads.Support for MSI/MSI-X provides performance benefits for multi-core servers by load balancing interrupts between CPUs/cores.
HPE 331FLR - network adapter - PCIe 2.0 x4 - Gigabit Ethernet x 4
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.0 x4
Ports
11.75 cm x 7.62 cm
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP
1 x Broadcom BCM5719
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1as, IEEE 802.3az
SuSE Linux Enterprise Server 11, SuSE Linux Enterprise Server 10, Microsoft Windows Small Business Server 2011 Essentials, Oracle Solaris 10, Red Hat Enterprise Linux 6.1, VMware ESX 4.1, VMware ESXi 4.1, Red Hat Enterprise Linux 5.7, VMware ESXi 5.1, VMware ESXi 5.0
Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10; ProLiant DL120 Gen10, DL180 Gen10, DL20 Gen9, DL325 Gen10, DL380 Gen10, DL385 Gen10, DL388 Gen10, DL560 Gen10, DL580 Gen10, XL170r Gen10, XL190r Gen10, XL270d Gen10, XL450 Gen10; SimpliVity 325 Gen10, 380 Gen10; StoreEasy 3850
Network adapter
Plug-in card
PCI Express 2.0 x4
Ports
Wired
Data Transfer Rate
1 Gbps
TCP/IP, UDP/IP
Remote Management Protocol
SNMP
Status Indicators
Port transmission speed, link/activity
VLAN support, full duplex mode, Jumbo Frames support, PXE support, LSO, Energy Efficient Ethernet, TSO, MSI-X, TCP/IP checksum offload, UDP/IP checksum offload
Processor / Memory
Expansion Slots
1 x FlexibleLOM
4 x Ethernet 1000 - RJ-45
FCC Class B certified, UL, VCCI Class B ITE, EN55024, FCC Part 15, EN 60950-1, WEEE, RoHS, ICES, VCCI V-3, EN 61000-3-2:2006, EN 61000-3-3:2008, KN22, KN24, EN55022:2006 Class B
5.5 Watt
Software Included
HP Systems Insight Manager (HP SIM)
11.75 cm
7.62 cm
55 °C
10 - 90% (non-condensing)
HPE Apollo 4520 Gen9 , HPE Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10 , HPE ProLiant DL120 Gen10, DL180 Gen10, DL180 Gen10 Entry, DL180 Gen10 SMB, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL20 Gen9, DL20 Gen9 Entry, DL20 Gen9 Performance, DL20 Gen9 Solution, DL325 Gen10 Base, DL325 Gen10 Solution, DL380 Gen10, DL380 Gen10 All Flash Server for Datera, DL380 Gen10 Base, DL380 Gen10 Entry, DL380 Gen10 Entry SMB, DL380 Gen10 for Cohesity DataPlatform, DL380 Gen10 for SAP HANA Compute Block, DL380 Gen10 High Performance, DL380 Gen10 Hybrid Server for Datera, DL380 Gen10 Network Choice, DL380 Gen10 Network Choice for CTERA, DL380 Gen10 NVMe All Flash Server for Datera, DL380 Gen10 Performance, DL380 Gen10 Server for CTERA, DL380 Gen10 SMB, DL380 Gen10 SMB Networking Choice, DL380 Gen10 Solution, DL380 Gen9 High Performance, DL385 Gen10, DL385 Gen10 Base, DL385 Gen10 Entry, DL385 Gen10 High-Performance, DL385 Gen10 Performance, DL385 Gen10 SMB, DL385 Gen10 Solution, DL388 Gen10 Network Choice, DL560 Gen10, DL560 Gen10 Base, DL560 Gen10 Entry, DL560 Gen10 for SAP HANA Compute Block, DL560 Gen10 Performance, DL560 Gen9, DL560 Gen9 Base, DL560 Gen9 Entry, DL560 Gen9 Performance, DL580 Gen10, DL580 Gen10 Base, DL580 Gen10 Entry, DL580 Gen10 Performance, XL170r Gen10, XL170r Gen10 24TB Server for Cohesity DataPlatform, XL170r Gen10 36TB Add-on Server for Cohesity DataPlatform, XL170r Gen10 Server for BlueData EPIC, XL170r Gen9, XL190r Gen10, XL190r Gen10 for HPE Ezmeral Container Platform, XL190r Gen9, XL230a Gen9 Compute Tray, XL230a Gen9 Compute Tray (12G), XL230a Gen9 Compute Tray (6G), XL230a Gen9 NHP Compute Tray (12G), XL270d Gen10, XL270d Gen10 for HPE Ezmeral Container Platform, XL450 Gen10 , HPE SimpliVity 325 Gen10 Node, 380 Gen10 G Node, 380 Gen10 H Node, 380 Gen10 Network Choice G Node, 380 Gen10 Network Choice H Node , HPE StoreEasy 1850, 3850 Gateway Single Node
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: PC
Compatibility: Unix
Brand: HPE
