HPE DX115 Removable HDD Frame/Carrier
Quicklinx: BFBBWS00 Mfr#: FZ576AA
The HP DX115 Removable Enclosure is a rugged drive carrier and receiving frame for internally mounting a SATA or SAS hard drive into a 5.25 inch optical drive bay in an HP Workstation.
HP DX115 Removable HDD Frame/Carrier - storage mobile rack - SATA / SAS - SATA, SAS
Storage mobile rack
Bus Type
SATA, SAS
Compatible Bay
1 5.25"
Hard Drive Form Factor Compatibility
3.5"
SATA / SAS
14.76 cm x 20.5 cm x 4.11 cm
1.73 kg
1-year warranty
Workstation xw4600, xw6600, xw8600, xw9400, Z620, Z820
Storage mobile rack
3.5"
Host Bus
SATA, SAS
Storage Controller
SATA / SAS
No CPU
Compatible Bay
1 x drive cage 5.25"
Rugged
Limited warranty - 1 year
14.76 cm
20.5 cm
4.11 cm
1.73 kg
HP Workstation xw4600, xw6600, xw8600, xw9400, Z620, Z820
