The HPE DL380 Gen10 Universal Media bay provides front Display Port and 2xUSB 2.0; plus support for 2x SFF front drives or 2 NVME front drives (826687-B21, riser required) and ODD support (Not included); and can only be located in Box1 in either an 8 SFF or 8+8 SFF model.
- HPE - storage drive cage - SATA 6Gb/s / SAS 12Gb/s / PCIe
- Storage drive cage - Universal Media Bay
- Expansion Bays
- 1 x internal , 2 x internal - 2.5" SFF
- Compatible Bay
- 1
- Interface
- Designed For
- Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10; ProLiant DL380 Gen10, DL388 Gen10
- Bay Compatibility
Storage Controller
- Interface
- Processor
- No CPU
- Bays
- 1 x DisplayPort , 2 x USB 2.0 , 2 x SATA 6Gb/s / SAS 12Gb/s / PCIe
- Compatible Bay
- 1 x internal
- Supports NVM Express
- Designed For
- HPE Nimble Storage dHCI Large Solution with HPE ProLiant DL380 Gen10 (2.5") , HPE ProLiant DL380 Gen10 (2.5"), DL380 Gen10 48TB Server for Cohesity DataPlatform (2.5"), DL380 Gen10 96TB Server for Cohesity DataPlatform (2.5"), DL380 Gen10 All Flash Server for Datera (2.5"), DL380 Gen10 Base (2.5"), DL380 Gen10 Entry (2.5"), DL380 Gen10 Entry SMB (2.5"), DL380 Gen10 for Cohesity DataPlatform (2.5"), DL380 Gen10 for SAP HANA Compute Block (2.5"), DL380 Gen10 High Performance (2.5"), DL380 Gen10 Hybrid Server for Datera (2.5"), DL380 Gen10 Network Choice (2.5"), DL380 Gen10 Network Choice for CTERA (2.5"), DL380 Gen10 NVMe All Flash Server for Datera (2.5"), DL380 Gen10 Performance (2.5"), DL380 Gen10 Server for CTERA (2.5"), DL380 Gen10 SMB (2.5"), DL380 Gen10 SMB Networking Choice (2.5"), DL380 Gen10 Solution (2.5"), DL388 Gen10 Network Choice (2.5")
